frozen pins
Post by Lavoy » Mon Jan 07, 2013 8:48 am
Thrust plate won't be visible unless the roller is disassembled.
Frankdozer
Post by Frankdozer » Mon Jan 07, 2013 9:39 am
So the thrust plate is part of the rear bottom roller? Frank
1984 John Deere 455D Crawler with 4 in 1 bucket
Post by Lavoy » Mon Jan 07, 2013 4:23 pm
Correct, inside of the end caps is a plate on each end that keeps the axle centered. If the plate or bolts break, the roller will walk back and forth til the end caps stop it.
andregrondin
Post by andregrondin » Tue Jan 08, 2013 11:27 am
here are some pics off rollers of a 350 straight.
hope this will help.
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
Post by jtrichard » Tue Jan 08, 2013 12:42 pm
350 rollers with set screws? for the pins
Post by Lavoy » Tue Jan 08, 2013 4:54 pm
Set screw goes into a recess on the axle to keep it from turning. For the most part, only seem to see these rollers on early crawlers, and then only if they have not been replaced.
Frankdozer
Post by Frankdozer » Tue Jan 08, 2013 5:10 pm
Why the set screw to keep them from turning? I thought they were rollers for the track..............?
Post by jtrichard » Tue Jan 08, 2013 8:06 pm
the axle shaft in the roller does not turn there is a bushing in the roller that rides on the shaft with sae140 or roller/corn head grease to keep them cool and lubricated i have only seen the set screws in very early rollers like 440/1010
Post by Lavoy » Tue Jan 08, 2013 9:40 pm
Sorry, should have clarified, the axle is stationary, the roller turns on the axle like JT says.
Scottyb
Post by Scottyb » Tue Jan 08, 2013 11:52 pm
Easy to see the damage from the sprocket hitting the roller.
The sprocket was hitting the roller on my 350b The 8 bolts that hold the rear cross member in place were..... 6 loose and 2 broken.
I loosened all 6 some more, centered the cross member with a sledge hammer, fixed the two broken ones and tightened all 8 back in. No more problem.
I hope your problem is as simple,
backhoe attachment.
Frankdozer
Post by Frankdozer » Thu Jan 10, 2013 8:13 am
All I know is that I'm hoping that the rear cross member just needs adjusting.....................Frank
Users browsing this forum: No registered users and 194 guests
