Hello everyone, hope all of you had a great turkey day,
I found out why the hyd sys is slow, the suction side is resricted,someone used a rubber line off the pump, half kinked and at the tank end the nut is tight but line is'nt, should this be a one piese line?
49-MC HYD LINE
- Dave Auger
Should be a one piece steel line. Nut at the tank is not a bid deal, the suction part of the line should be below the oil level.
- Dave Auger
MC HYD LINE
HI, I'm looking for a hyd line for a mc , from the hyd tank to the pump,the parts man. # is key#9--part#m1346t Thank's Dave
MC hydraulic suction line
I had same problem, I cut the existing piece of steel and shoved a piece of hydraulic hose over the steel , at the ends and used 2 hose clamps per end, works fine on my MC
- Dave Auger
Users browsing this forum: Google Adsense [Bot] and 325 guests
