JD 1010 and JD MC
ld7mile
JD 1010 and JD MC
Post by ld7mile » Mon Nov 26, 2012 2:10 pm
Which parts JD MC and JD 1010 will interchange?
ljs
waterman28
Post by waterman28 » Mon Nov 26, 2012 2:45 pm
Not many, Lavoy might run down the list of all 3 things for you.
JD 1010 Crawler
Ferguson TO 30
Case 580C
996 David Brown
Post by Lavoy » Mon Nov 26, 2012 4:27 pm
Nothing that comes to mind other than oil.
Post by jtrichard » Mon Nov 26, 2012 6:47 pm
i was thinking the same thing oil.. coolant... radiator cap? gas maybe.... but 1010 could be diesel LOLOL
ld7mile
Re: JD 1010 and JD MC
Post by ld7mile » Tue Nov 27, 2012 11:27 am
ld7mile wrote:Which parts JD MC and JD 1010 will interchange?
Hey, thanks for the information. I need a set of chains for my Jd 1010, but if I buy them from John Deere they cost more than I paid for the dozer. I can buy the John Deere MC for a little more than 1 chain will cost.
ljs
Post by Lavoy » Tue Nov 27, 2012 1:29 pm
There are no new 1010 chains in spite of what your dealer may have told you, haven't been in more years than I can think of.
If you need chains, I might have a set, or my brother might. Or, I can get you new 350 chains and you can convert the crawler over.
townlineterry
Post by townlineterry » Tue Nov 27, 2012 4:15 pm
I have to ask, since I may be in the same situation at some point. What do the 350 chains cost and what is involved in the conversion?
Post by Lavoy » Tue Nov 27, 2012 5:27 pm
It will vary with brand, but roughly $1000 per side for new sealed interlock chains. Bolt set is about $150, pads if you need them will depend on style and width, but $1000 for the pads is a close guess.
ld7mile
Post by ld7mile » Wed Nov 28, 2012 7:15 am
Lavoy wrote:It will vary with brand, but roughly $1000 per side for new sealed interlock chains. Bolt set is about $150, pads if you need them will depend on style and width, but $1000 for the pads is a close guess.
Lavoy[/quote.
Yes, you are correct the dealer did say 350 chains. Are you saying both sides for $1500? My pads are ok. Will they fit the 350 chains? They are 4 bolts.
ljs
Post by Lavoy » Wed Nov 28, 2012 10:03 am
No, $1000 per side. Yes, your pads are a direct bolt on. You will need to rerim your sprockets with 350 rims as well.
Users browsing this forum: jimmydiesel and 186 guests
