crawler no. 2
crawler no. 2
Post by NNAATZ » Fri Nov 09, 2012 9:31 pm
all excited, goin to pick up a 40c loader with 5 roller track in the morning. its well used and abused, it runs and steers one direction. clutch is froze.
ill get pics up soon.
Post by NNAATZ » Sat Nov 10, 2012 8:49 pm
got it home. working on pics yet. took some with a phone tryin to get them up
Post by NNAATZ » Sun Nov 11, 2012 9:43 am
think i got figured out, pics are by phone so i had get them from zip file to jpg file then to photo bucket.
pic of busted loader
winch missing parts dont know if salvagable yet.
just got it home on the trailer yet.
it runs great, drives, right clutch froze. tracks are toast one link removed sprockes fair, rollors and ider are great, looks to be 420 sprocks. verious welding everwhre.
Post by NNAATZ » Sun Nov 11, 2012 12:21 pm
it is a 420 after closer inspection, has water pump. any info on the loader is appreciated
Post by Lavoy » Sun Nov 11, 2012 5:35 pm
Looks like an ID tag right under the seat, but reasonably sure the loader is a Greenville or ATECO loader, winch is a gearmatic, but can't tell model, RH side plate is homemade.
CatD8RII
Post by CatD8RII » Mon Nov 12, 2012 9:58 am
Could the loader be a Henry? Almost looks identical to the one on dads's 420. The only thing that looks different are the bucket links (cranks?) It would appear that they have been repaired though.
Take a look here
http://www.jdcrawlers.com/messageboard/ ... ight=henry
Post by NNAATZ » Mon Nov 12, 2012 5:36 pm
my first impression was a henry too. i seen the tag, never bothered to look at it. i kinda bought it sight unseen through cell pics. for what i paid it was a deal in any capacity. the owner said it was a 40. thought id use it for parts, but dont have the heart to knock it in the head yet. it dose run, i do have the sheet metal for it, none of the castings are broke except for one ear on the clutch housing and been repaired some time ago, still holding. maybe scavenge parts for the winch?? like to remove the loader and replace with a blade. find rails in usable wear?? with pads... repair froze clutch. find top rollers to replace the wood blocks. then use it to pull that lil' sraper ive got... we'll see got enough on the plate for now
Post by Lavoy » Mon Nov 12, 2012 6:29 pm
Yeah, could be right, ATECO and Greenville are similar to Henry, I can't remember the difference right now, but seems to me it is obvious if I could remember it.
You know you got it bad when you buy a parts crawler, then you have to fix it up cause you can't bear to kill it. Then you need another parts crawler, and the circle continues. :lol:
Post by NNAATZ » Mon Nov 12, 2012 7:38 pm
lavoy you're rite, its vicious cycle. worse been restored and better been scraped.lol back to the loader the bucket cylinder mounts in diff location the bellcrank arms are more radiused and main up-rites are bent diff. this one one not mactching the henry that catd8RII linked up.
Post by Lavoy » Mon Nov 12, 2012 11:21 pm
Okay, finally found it. It is a Henry TS-40F Industrial Tractor Shovel for 40 and 420 crawlers. 1900lbs in weight, $1165 list price less bucket, F.O.B. Topeka, KS, May 1, 1956.
Post by NNAATZ » Tue Nov 13, 2012 8:05 pm
tx for the info. the loader was kinda expensive at 1/3 the price of the tractor. what is new and wore rail height? i have decided im gonna save it..... crap now i need to find a parts crawler...
1954cooter
Post by 1954cooter » Tue Nov 13, 2012 8:19 pm
Thats the spirit !!!!!!!
Cooter
Post by NNAATZ » Wed Nov 14, 2012 8:13 pm
the plan is for now is too keep an eye out for tracks, would like to remove the loader and replace with a blade find one or build it and kinda would like to fix the winch too.
i'd even consider 350 convertion on this
this project wont take place till at least next spring.
Post by Lavoy » Wed Nov 14, 2012 8:29 pm
I've got more parts available for the winches now than I used to. Some of them are unfortunately more expensive than I would like, but at least I can get them now.
Seems to me new rail height is 3 1/8", can't find my track gauge right now.
Post by NNAATZ » Fri Nov 16, 2012 8:11 am
the rails measure a strong 3 1/16 by tape measure. so some are usable.
as far as the winch goes, all parts are MIA. need the break band, slave and related springs and parts. th clutch band or shoe, spider and slave, end plate(maybe fabricate that?) the bango or slew fitting. master control, fab that too?.
lavoy, what do u have for parts? thanks nicknaatz@yahoo.com
Users browsing this forum: No registered users and 182 guests
