Removing a broken bolt the easy way
- Paul Buhler
Deleted: I got tired of looking at my poor joke whenever I checked this thread. Paul
Some great tips here. Someone makes a welding rod just for this purpose, Extractalloy I think it's called. I've seen my dad take out many bolts that were broken halfway down the hole, welding straight out without letting the arc touch the sides, then putting a nut at the surface and welding to that. He's good at it though.
broken bolts
another way i use quite frequently is heat red hot with a rose bud torch quench with cold water or let cool over night and have done all that have been mentioned.
jim
jim
The rods I have used for pulling studs or bolts are Supermissleweld and High Ally 400 (might be 500, can't remember). They are a high elongation stainless with a super tough flux, the arc will not blow out throw the flux if you touch the side of the hole with the rod.
If doable, I would be inclined to pull the rest of the bolts and get the manifold off, then see if you can get at the broken stud. I normally try not to use this method out of position, but that may be more a function of my welding skills.
Users browsing this forum: No registered users and 145 guests
