450D T handle linkage kit
tuney443
Post by tuney443 » Wed Sep 12, 2012 1:06 am
Anybody know of an aftermarket linkage kit for a 6405 blade? Deere part--AT64924.The last time I bought one was app.1981 and it was something like $100,now it's app. $1,100!
JD35D midi exc.
JD410G TLB
JD450D Dozer
2 JD 440 track loaders
JD 420 track loader
JD 450C track loader
Al Swearengen
Post by Al Swearengen » Wed Sep 12, 2012 10:35 am
Just a thought...can't you remove the linkage, find the slop points, drill them out to fit tight with new pins?
Post by Lavoy » Wed Sep 12, 2012 3:11 pm
Not much meat to drill them out, but I have welded then shut, and then re-drilled.
kedorland
Post by kedorland » Wed Sep 12, 2012 8:37 pm
I was contemplating filling in with brass...then drilling out. Leaning towards the logic the remaining brass would "self lubricate" the piviot points.
Kevin from Iowa.
1975 450C. 1977 450CA loader, with winch and log arch. Is true..tracked equipment is addicting.
Post by jtrichard » Wed Sep 12, 2012 11:48 pm
brass would be best would have a bearing that it never had before
tuney443
Post by tuney443 » Thu Sep 13, 2012 7:39 am
What exactly are those pins called and how do you mushroom the ends once they're in the hole? Also,where do you get them?
JD35D midi exc.
JD410G TLB
JD450D Dozer
JD 420 track loader
Post by Lavoy » Thu Sep 13, 2012 7:49 am
The old ones were just roll pins, didn't know they changed them.
LeonardL
Post by LeonardL » Thu Sep 13, 2012 12:27 pm
They haven't changed them. They have been "Roll or Spring" pins for as long as I can remember. There is a difference between a "Roll" pin and a "Spring" pin. However both were used for years in this application and I think it only mattered what Deere had on the line at the time of assembly.
A "Roll" pin is just that... A tightly rolled pin made from a very thin piece of spring steel.
A "Spring" pin is a hollow pin with an open slot the full length of the pin. It is also made of spring steel. Most people will call them "Roll" pins and that's okay. I do the same thing. It is only purest machinists that will set you straight on the difference. They both do the same thing. However the real "Roll" pin is stronger but is harder to install.
There are also "Wedge" or "Tapered Groove" pins that Deere used that are tapered slightly to one end. Usually with embossed groves down the length of the pin and were considered to be a one time use pin. They were also directional. You installed them in a given direction and then had to remove them in the reverse direction. Some times proving to be a real challenge to remove. As far as I know these weren't used in this application though.
Post by jtrichard » Thu Sep 13, 2012 2:00 pm
Leonard its nice to see some one that knows what a split pin is .....i bet you cringe when someone asks for a FREEZE PLUG ......on my 2010 some of the pins would not stay in so i put 1/4 bolts in them worked great
Post by Lavoy » Thu Sep 13, 2012 8:56 pm
I have always seen the spring pins referred to as roll pins, and the wound pins as Spirol pins, learn something new here everyday. Of course my problem is remembering anything I learn! :lol:
tuney443
Post by tuney443 » Thu Sep 13, 2012 10:09 pm
I also thought at first they were just roll pins but mine like I said are mushroomed on each end so they don't fall out. I know for a fact these are original as I bought this dozer almost new in 1985.If they were just regular pins,with all the slop I have they would have fallen out long ago.Did grind about 1/4'' off the edge of the hyd. reservoir hatch so now at least I have easy full control of raising my blade.Will tackle this sloppy linkage on a rain day.Thanks everyone.
JD35D midi exc.
JD410G TLB
JD450D Dozer
JD 420 track loader
LeonardL
Post by LeonardL » Fri Sep 14, 2012 6:55 am
John Deere parts page shows your 450D with a 6405 blade control having several spring pins and two "Chain Links" as being the pivot mechanisms for the controls. I'm wondering if the pins you say are mushroomed on the ends are the chain links. They will have a swedged appearance at the pins on the links. Just a thought... :D
Post by digitup2 » Fri Sep 14, 2012 10:47 am
I remember trying to fix a set of those that were worn out when I bit the bullet and bought the new cast pieces . T bar worked best after though I know that I remember walking out of the dealers with a hand full of cast iron and a hell of a bill thinking it's not like it's electronic's or hydraulics's!!guess what I am saying is You really need to buy the dam little cast pieces and roll pins and that T bar will work like new .Remember how you took that apart OK!![There was an up grade on the nylon bushing on the handle If I remember ] some we had to put two bushings on or even a thin stainless washer to set handle straight up.Digitup.
tuney443
Post by tuney443 » Fri Sep 14, 2012 11:53 pm
LeonardL wrote:John Deere parts page shows your 450D with a 6405 blade control having several spring pins and two "Chain Links" as being the pivot mechanisms for the controls. I'm wondering if the pins you say are mushroomed on the ends are the chain links. They will have a swedged appearance at the pins on the links. Just a thought... :D
No,not referring to the chain links.
JD35D midi exc.
JD410G TLB
JD450D Dozer
JD 420 track loader
tuney443
Post by tuney443 » Fri Sep 14, 2012 11:58 pm
digitup2 wrote:I remember trying to fix a set of those that were worn out when I bit the bullet and bought the new cast pieces . T bar worked best after though I know that I remember walking out of the dealers with a hand full of cast iron and a hell of a bill thinking it's not like it's electronic's or hydraulics's!!guess what I am saying is You really need to buy the dam little cast pieces and roll pins and that T bar will work like new .Remember how you took that apart OK!![There was an up grade on the nylon bushing on the handle If I remember ] some we had to put two bushings on or even a thin stainless washer to set handle straight up.Digitup.
Like I originally said--yes,it was about $100 for that kit 30 years ago.Now it's $1,100.NOT worth it by a long shot.I told my dealer Deere should be ashamed at that price--the feeling I get is they want you to update to new or newer and let the old iron be scrapped.
JD35D midi exc.
JD410G TLB
JD450D Dozer
JD 420 track loader
Users browsing this forum: No registered users and 218 guests
