I have a 1984 JD 550B. It has recently started leaking transmission oil from somewhere around the frame level. it only leaks when the fluid heats up. so when i Idle down to look for the leak it stops. it is possibly comong from where the transmission cases come together or one of the hard lines that goes into the bottom of the transmission. Anyone got any suggestions.
thanks
walt
Transmission Leak
Stump pan
I would pull the stump pan, run it up on some blocks and take a look. Follow the oil cooler lines, if your lucky it will be a cooler line. Common problem on 350's.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Users browsing this forum: No registered users and 360 guests
