jd350 final drive
jd350 final drive
Will a final drive off of a jd350 fit a jd350b?? Thanks
If you go solely by the online JD parts manuals, there is a serial number break at 20538 for the final drive assembly on a straight 350; beyond that the parts numbers for the final drive assembly are generally the same between the later straight 350s and the 350Bs.
Someone else on here will have to let you know whether there are any other differences, and whether the final drive from an early straight 350 will fit on a later straight 350 or 350B.
Users browsing this forum: No registered users and 246 guests
