Larry 8N75381
Post
by Larry 8N75381 » Thu Jul 12, 2012 2:31 pm
The cylinder on the track adjuster for my 350 has a crack in it - see below.
A search of the web finds an after market replacement that looks like this;
At the base is what looks like a standard pipe plug. My question is, "How do you get grease into the cylinder to stretch the track out tight?" Has someone used one of these replacement adjusters that can tell me, OR better still take a picture of one on a machine?
Thanks,
Larry
PS
Here is an exploded assembly drawing that shows an adjuster like that in the previous photo. BUT, there are no grease fittings shown.
CLICK TO ENLARGE.
Oliver OC-4 Dozer, '67 Ford 3000, '48 Ford 8N75381, '67 JD 350 Loader
Willyr
Post
by Willyr » Thu Jul 12, 2012 2:38 pm
It is a pipe thread. On my Case 350, you screwed a grease gun directly into the cylinder. Then pump away till it got tight or your arm got tired.
Post
by Tigerhaze » Thu Jul 12, 2012 2:41 pm
I can't see the photo here at work, but the external pipe plug on most aftermarket adjusters is just a protective cover to keep dirt out. Once you unscrew the plug the standard zerk fitting to pump grease is inside.
If I get to my farm this week I will take a photo of my aftermarket adjuster.
CatD8RII
Post
by CatD8RII » Thu Jul 12, 2012 3:54 pm
Tigerhaze is correct, you just unscrew the pipe plug and you can get to the adjuster valve. It has a standard zerk fitting. To loosen the track you take a 7/8" socket and unscrew the valve no more than 1 turn. Just make sure the valve is snug again before pumping the tracks back up.
carolina crawler
Post
by carolina crawler » Fri Jul 13, 2012 6:51 am
I bought a pair of these for my 350b........way better then that old JD adjuster.........highly rec.
1978 350b loader w/winch
- Site Admin
Post
by Lavoy » Fri Jul 13, 2012 10:23 am
I have installed and sold several of the adjusters in the pic, they work fine.
Larry 8N75381
Post
by Larry 8N75381 » Fri Jul 13, 2012 10:05 pm
Thanks to all that replied.
I will be ordering the after market adjuster.
Larry
Users browsing this forum: No registered users and 159 guests
