Starter for 350 Crawler Dozer
Arkdozer
Post by Arkdozer » Fri Jun 15, 2012 7:35 pm
T4F3D SN/ 106552T 1970.. if I read the s/n listing correctly
Hi All, I am new to the forum Just bought a 350 dozer. Need info on replacement starters. Will the starter for a 350B work on a straight 350 ??
I think the info I have gleaned so far indicate a delco 28mt
Any Advice will be greatly appreciated
Thank You
Fred
Belchos
Post by Belchos » Sat Jun 16, 2012 12:37 pm
Is the starter missing? I just had mine rebuilt. 200 bucks, but it's "brand new."
Arkdozer
Post by Arkdozer » Sat Jun 16, 2012 2:27 pm
The starter is there it just clicks when you turn the key, shorting across the solenoid produces the same result
Paul45
Post by Paul45 » Mon Jun 18, 2012 5:54 am
http://www.jdcrawlers.com/messageboard/ ... php?t=7163
Read this post, mine would click 25 times before starting. I bought a new one list in this post and got it three days. good luck :D
thanks Paul
350 track loader, 350 dozer
LeonardL
Post by LeonardL » Mon Jun 18, 2012 8:31 am
Before you go and pay for an expensive starter, try just replacing the solenoid first. They are the common old Delco small block starter solenoid and any parts store should have one cheap. Go the cheap route first and then look at your starter. You can also loosen the lock nut on the main battery lead post on your existing solenoid. Push the stud inside the cap enough to be able to turn the stud 180 degrees. Pull it back out until you feel it set back into its locked position and then tighten the lock nut. I've done this at least a thousand times. Most of the time it is usually either a grounding problem or the solenoid when these starters do this.
Arkdozer
Post by Arkdozer » Tue Jun 19, 2012 7:05 am
Thank you Paul,
I have the new style fuel pump shown in the photos, looks like quite a project. I think I would get a new tisko pump before trying those modifications, or have my original starter rebuilt.
Thank you Leonard,
For your tip on it being a defective solenoid. I tested the voltage going to the starter from the solenoid while turning the key and had zero volts, so this will be my starting point
Fred
Users browsing this forum: No registered users and 216 guests
