stering clutches
petty
stering clutches
Post by petty » Mon Jun 11, 2012 6:52 am
while working my dozer started smelling something. steering clutches had strong amonia odor and right side quit pulling. parked it for a few hours went back and tried it pulled forward and back with left side locked but didnt put under load.did i ruin the new clutches or is there hope.also i believe the right track was to tight,working in gumbo and might have been problem.when i took plate off under seat very hot in housing.
1966 350 straight gas
1930's GAR WOOD scraper dirt pan
cdunn
Post by cdunn » Mon Jun 11, 2012 5:05 pm
Brake band too tight? I had similar problem with my 350 straight, too tight brake band was problem. New bands are hard to get adjusted right untll they get "seated"( I guess would be the word for it)
57 420c 86 Ford 4600
67 350 dozer
66 350 loader
58 Oliver OC-4
48 8n Ford
49 Farmall Cub
Struck Mini-Dozer
CELSESSER
Post by CELSESSER » Mon Jun 11, 2012 5:43 pm
The first thing I thought when I saw "strong smell of amonia" the very first thing that came to my mind was mouse piss. I carry a fire extinguisher in the tractor at work for the inevitable electrical fire that will happen in the overhead counsol due to mouse piss. On these 80 degree days I wish it was open station. Guess one of these days I will have to pull it all down to rewire the whole mess.
I am sure CDunn is correct on the brake band. If it moved correctly when it had cooled down
petty
steering clutches
Post by petty » Mon Jun 11, 2012 6:23 pm
so what you are saying is the brake band was seizing up even though it would still roll forward with no levers pulled back while it was hot?can to tight of a track cause any problems like that,i didnt lossen them up going into the gumbo.
Users browsing this forum: No registered users and 44 guests
