gearmatic winch installation on 440 crawler
dondeere
Post by dondeere » Tue Jun 05, 2012 1:52 pm
I just restored a gearmatic winch and am in the process of installing it on the crawler, took the cover off the PTO housing and see that there is a male 21 spline shaft. On the John Deere winch mount there is a gear on one side to mate to the winch and on the other side there is also a 21 spline male shaft. Is there a special coupling that goes on or do I have to change the complete shaft in the John Deere winch mount housing?
Post by Lavoy » Wed Jun 06, 2012 7:40 am
Same coupling as used on the PTO shaft, seems to me $50 or so.
dondeere
Post by dondeere » Wed Jun 06, 2012 7:53 am
am going out today to see if I can find one, was going to try and use the front part of a drive shaft yoke from a 21 spline drive shaft, will cut off 3 inches and use that. Its hard to find an actual PTO coupler in my City.
akjayjay
Post by akjayjay » Fri Jun 08, 2012 2:04 pm
Call this place it's where I got mine they have tons of jd parts pb&h 888-588-3005 they are really good
dondeere
Post by dondeere » Fri Jun 08, 2012 5:24 pm
ok, will do thanks
dondeere
gearmatic winch not working
Post by dondeere » Mon Jul 16, 2012 9:24 am
have it all installed, but the winch does not work, It will not winch in or out, the winch is turning inside when the pto is engaged, but when the lever on the control is activated it does not make it engage. Is there any tests that can be done, the controller has been rebuilt, new clutch hose and nipple, new lines, etc, etc, any ideas?
Post by Lavoy » Mon Jul 16, 2012 11:18 am
Bleed the air out if you have not already.
dondeere
Post by dondeere » Mon Jul 16, 2012 9:13 pm
I pumped and pumped and cracked open the lines and nothing but pure fluid came out...............but still nothing. If you open the barrel bung inspection cap you can see it turning, but when the levers are moved it just keeps spinning and nothing happens?, thinking maybe the linings are slipping or its way out of whack on adjustment. After all that work and money am disappointed.
Post by Lavoy » Mon Jul 16, 2012 9:25 pm
You have to look and see that the clutch slave cylinder is expanding. Just because you have fluid at the fitting on the side plate, does not mean that the cylinder itself is not full of air. The clutch slave cylinder has to move virtually immediately upon moving the master control lever. Once that has been checked and still no clutch, most likely you are looking at a clutch band adjustment issue or some other mechanical problem, but still most likely related to the clutches. It will work, you just haven't found the problem yet.
Users browsing this forum: Google Adsense [Bot] and 275 guests
