Pat
Post
by Pat » Thu Feb 23, 2012 6:41 pm
ktheaker
Post
by ktheaker » Sat May 26, 2012 4:45 am
the atatchment points on the dozer are included with this setup ? the 1010 that i have just has a push manual blade and i am showing some interest in the set- up and just asking is there anything missing that i require to install on the frame
kt
Post
by JD440ICD2006 » Sat May 26, 2012 5:46 am
Curious, how are the ends that connect to the blade of the the angle cylinders (two in the middle of pic) held on? Are they screwed on or spun welded?
Thanks,
- Site Admin
Post
by Lavoy » Sat May 26, 2012 4:06 pm
They are threaded on.
ktheaker
Post
by ktheaker » Sat May 26, 2012 6:24 pm
are the hydrolic pumps the same for the 1010 non angle blade as the hydrolic angle blades - the pumps are the same out put ? and the lines are all that is nec to change up or was the pump a higher output ?
kt
- Site Admin
Post
by Lavoy » Sun May 27, 2012 9:57 am
Pump is the same, valve and all the lines are different.
