2010 Track Adjuster partsr
I am looking for the outer part of a hydraulic track adjuster for a JD 2010. Mine cracked along the length. I had the track quite tight as I was having trouble with the track coming off the left rear sprocket.
An aftermarket adjuster might be the answer or perhaps go to mechanical adjusters. The root cause of my problem seems to be the track coming off and I thought keeping it tighter was the answer. After I reverse and lock the right track up to turn I think with the track looser I just drive out of the links when I go ahead. If there are adjusters available I would appreciate the information.
Users browsing this forum: No registered users and 175 guests
