These new starters are a great deal for $95 brand new. I just found out that Tisco sells a fuel pump that fits just fine. Looks like a European Sofabex pump like Deere used on some French and German tractors.
DB Electric. $110 on his Website and sometimes cheaper on Ebay. Often free shipping. Nice thing is the starters are brand new and an improved technology. You don't trade in your old one so you can fix and save for a spare. My original Delco just needed brushes, drive and s solenoid kit. $75 in parts and it takes me a week to get. I bought the new starter first and installed so no down time. $110 everday price and sometimes sale-priced at $95.Paul45 wrote:I am in need for a new starter on my 350, I have to keep turning key about 10 to 15 times before it will crank over, its worst when hot.
Can you list where you found yours? Thanks
That sounds like it's just the solenoid.Paul45 wrote:I have to keep turning key about 10 to 15 times before it will crank over, its worst when hot.
Yes, the solenoid contact disk or the starter brushes. Both can cause a "click" instead of start until several attempts are made.tjdub wrote:That sounds like it's just the solenoid.Paul45 wrote:I have to keep turning key about 10 to 15 times before it will crank over, its worst when hot.
When the starter on my 2010 diesel started having problems, it clicked like it was the solenoid but it ended up being bad brushes. In hindisght, the clue was that the starter seemed to turn slowly even with a fresh battery. Once I replaced that starter, it turned the engine over about twice as fast and made starting the 2010 a whole lot easier.jdemaris wrote: Yes, the solenoid contact disk or the starter brushes. Both can cause a "click" instead of start until several attempts are made.
If the solenoid contacts are the problem, it will keep on clicking and working for a long time. If the brushes are the problem, things get worse fast.
I bought mine through the Yesterdays Tractors Website. It's a Tisco brand. Probably same as what your're getting. Cost me $43 plus $8 shipping and no tax. It has the metal clean-out bown on top and looks exactly like the French made Sofabex pumps that Deere used to sell for ag-tractors. Fits perfect. Here's the description from their Website.mniebuhr wrote:I'm working on a JD 1020, same problem, looks identical to the pics you posted. You mention Tisco having a fuel pump that fits, I assume w/out modification. Is it the part #TP-RE42211B (http://www.tractorpartmart.com/us/index ... t_id=11507)? (Looks more similar to the original w/ the bowl on top.) Thanks!
Users browsing this forum: No registered users and 253 guests
