1959 JD 440ICD sees sunshine!
Post by JD440ICD2006 » Sun May 06, 2012 9:39 am
I was determined to move the 440ICD yesterday. The nose was lifted in to place and bolted on. The 6 way blade was installed, and well...........
I was so excited I did not think about getting video. But the pics tell the story.
Post by digitup2 » Sun May 06, 2012 2:31 pm
Once it's running nice your tracks are on back words .Always lead with the grouser on the track pad It will run like that but it takes a lot more power and wears faster .Looks good though damn I wish I had the time to fix one up I keep pulling the old crawlers in the old shop and parking them .Some day I will start on the old Deere's I keep threatening the mechanics that when they have spare time I am going to get them busy on the old stuff .The youngest mechanic has done some work and has a chance to get several running that weren't at this point a2010 a 430 and a 440 are running nice.even the clutches are set on the 40c it is running like a charm .But as usual I have little time to work on the old iron .Digitup.
Post by JD440ICD2006 » Sun May 06, 2012 2:57 pm
Digitup,
You know that I always appreciate and respect your input, you are a very valuable asset to this site.
You would not believe how many times people have pointed out the tracks are on backwards after I began to post pics of the rebuild.
I checked it over, and actually the crawler is on backwards. The tracks are on right. :lol:
Changing the tracks is one of the first next steps. I have another set of 440 tracks. My plan is to drive it on to those tracks, reverse my tracks, and then back it on the tracks and pin them back on.
Do you know of a better or easier way?
Thanks,
Chuck W.
waterman28
Post by waterman28 » Mon May 07, 2012 8:52 am
JD440ICD2006 wrote:Digitup,
HAAHAAHAA that cracked me up!!!
JD 1010 Crawler
Ferguson TO 30
Case 580C
996 David Brown
Post by Paul Buhler » Mon May 07, 2012 6:32 pm
What ever make the most sense to you and your equipment /help is the "best way". I like your explanation of the problem. :D Paul
carolina crawler
Post by carolina crawler » Mon Jun 18, 2012 6:10 am
looks good chuck.....still trying to locate new or decent used front idlers for the 350....and do you have a trick to driving in a master pin?...hit me on the cell.
1978 350b loader w/winch
petty
Post by petty » Fri Jun 22, 2012 4:55 pm
not sure if you have ever heard of it. there a pretty good size crawler graveyard down here in south ga. BLOUNTS EQUIPTMENT. i believe they have a web site also. have rode down some of the roads lots of jd crawlers and have bought some pretty descent used parts.
1966 350 straight gas
1930's GAR WOOD scraper dirt pan
Users browsing this forum: No registered users and 33 guests
