350 staight in garage for preventive maintenance
andregrondin
Post by andregrondin » Wed Mar 07, 2012 9:34 am
Hi !
Leonardl , thank you for the comments as well as the tip about the brass plug ! point well taken and it will be fix asap, very good point I did not think of those obstacles than could damaged the plug .
here are some more pics of the work I did last evening .
cleaned the alternator.
fix the lower radiator holder.
finished the cleaning of the front and right side of the motor
check of the temp. sensor .
fixed of the radiator top side holder from rivets to bolt
I undid the hydraulic oil pump as well .
cleaning of the alternator
fixed of the radiator top side holder from rivet to bolt
check of the temp sensor conductivity
meter in DIODE test mode to hear the BEEEP of continuity
check of the temp. sensor at room temp
meter on OHM mode
check of the temp. sensor at slightly heated temp
the famous gauge which I think it is not accurate at all but need to verify
undoing the hydraulic pump
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
andregrondin
Post by andregrondin » Wed Mar 14, 2012 12:00 pm
Hi !
More pics of more work .
hydraulic pump shaft & disengaging clucth .
all dimantled, cleaned, lubicated et remounted , by the way I remounted the fork the opposite way because she was too worn and I couldn't weld ( casting) and it it and fearture that we do not use very often so I took a chance not to put too much work on it .
hopefully not being to anoying with all this !!
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Post by Tigerhaze » Wed Mar 14, 2012 12:23 pm
andregrondin wrote: hopefully not being to anoying with all this !!
iIdon't think anyone will say that too many photos is annoying- keep them coming :D
andregrondin
Post by andregrondin » Mon Mar 19, 2012 7:48 am
Hi !
Some more pics of the maintenance .
brand new water pump by-pass hose. (no not my best pic !!lol)
re-install of the rad :
re-install of the front end :
wires in tube to prevent rubbing to frame and create problems :
re-wiring and checking gauges and sender :
instalation of the micro switch for the back-up alarm: (look at red clip )
some gizmos
1- bracket for and backup-alarm
2- 12v oultlet for cigare lighter type electrical apparatus can be be connected.
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Tom in Mo.
Post by Tom in Mo. » Thu Mar 22, 2012 5:17 pm
Nice work. I admire your ambition.
1966 450 Diesel 6-way Dozer
1965 2010 LP gas rowcrop
1967 1020 gas utility
a bunch of Fords
Patrick
Post by Patrick » Fri Mar 23, 2012 9:34 pm
I see you built new radiator cushions. I Just replaced those upper radiator cushions on mine. Some one before me bolted them solid. Im surprised the radiator held up. Watching it with the hood off that thing really jiggles around.
Pat
andregrondin
Post by andregrondin » Mon Apr 02, 2012 11:16 am
Hello !
A little update here .
new wear bar welded
idler are back too
and two rollers also
enjoy !!
idler had there center ledge plasma reduced , I'm trying this method
instead of having the idler reloaded since reloading is tricky due to the fact that the idlers are CAST iron , time will tell if I made a good or bad decision !! it wouldn't be my first and last mistake .
rollers
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
andregrondin
Post by andregrondin » Thu Apr 05, 2012 7:56 am
Hello !
is are more pics of the work in progress :
all rollers are on ( top & bottoms )
tracks are ready to be re-attached ( this evening 2012-april 5th ) .
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
andregrondin
Post by andregrondin » Fri Apr 06, 2012 8:01 am
Hello !
Yep me again !
the tracks are back on the dozer and the engine is purring so good !!!
Man can't wait to push dirt !!!!!
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
440 iron popper
Post by 440 iron popper » Sat Apr 14, 2012 3:09 pm
Very good Pics! I think it's almost better than a service manual :) . It will help many people fixing their 350 for shure. I hope you can try the beast soon!
Post by Paul Buhler » Sat Apr 14, 2012 5:14 pm
Careful, thoughtful, and thorough work will be rewarded with a reliable machine. I hope you enjoy hours of worry free digging. Thanks for sharing your pictures. Paul
andregrondin
Post by andregrondin » Mon Apr 16, 2012 11:50 am
he is the latest and the hottest .
only thing left is to fix 2 leaking cylinder
and putting back one pad that was distorded .
and the engine puurrrs very well !!
brake & clutch are re-adjusted and ready for a road test ! heu field test !!
One of my goal here is very simple , give back what I fetched , which means I asked a lot of questions and help on doing my work and now it is payback time with my work and pics , if this help anyone fixed their machine than I'm glad to do so , I love to share my experience good or bad .
We are very fortunate to have internet and acces to fast picture taking and hosting so why not use the technology for a good cause in a good way .
thank you to all for your help ! don't you worryI'l be back with more questions casue I intend to repack my cylinder by my self !!!
top rollers are back :
rock guard are back :
footplate are back :
enjoy ,
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
andregrondin
Post by andregrondin » Tue Apr 17, 2012 7:34 am
Hello !
Here I go again ,
Update the shifter knob as well as blocking third & fourth gear ( so my friend can't do any race with it ( he's a machine destroyer ) .
removed cleaned & re-assemble the oil-level window.
was I happy to throw out the sloted screw !!! lol
change my hydaulic oil reservoir filter !! what a great idea !
the filter was so old ( I only have the dozer for a year now but the filter had been there since 1966 ( I think )) that it was loosen and it tilted to the back so I had a fair share of problem to remove it from the tank, I had to crush it with a pry bar.
Also cleaned the micronic filter , it was very filthy as well as the tank .
filled back the tank using paint filter to make sure I wasn't putting back any sediment in the tank.
here are the pics .
enjoy !!!
knob
oil-level window
removal of hydraulic oil filter cover
removal & cleaning of the micronic filter
re-assembly of the micronic filter
re-assembly of oil filter
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
andregrondin
Post by andregrondin » Wed Apr 18, 2012 11:19 am
HI !
belly protection pan is back on.
The dozer is out the garage but it is not steering properly at all !!
I suspect a bad steering clutch adjustement ,
was too late last evening so it will have to be another day .
I find it very hard and akward to adjust those cluchtes & brake we see nothing in that black pit !!!
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Scottyb
Post by Scottyb » Wed Apr 18, 2012 12:39 pm
I just noticed your serial number on the 350, and, I had thought from posts on FAQ's that the numbers started at 10000. I have been thinking that my 350 serial was very early at 10285t however, if your number is correct, then I am needing to correct myself. I have been assuming mine was the 285th off the line. I may have to go back and edit a few posts. :oops:
Great job on the restoration, and I hope you get those clutches figured out soon. I have at times made several attempts, following the instructions carefully, before I could get them to work properly. I can't explain why it has not always worked for me on the first try???
backhoe attachment.
Users browsing this forum: No registered users and 231 guests
