550 trans rebuild
Post by digitup2 » Sun Apr 15, 2012 12:53 am
This really isn't strictly a Deere problem but dose occur I know the Allis Chalmers crawlers had internal leaks but the oil frothing wasn't the issue there the loss of oil pressure was the main thing .Digitup,
adamshuss
Post by adamshuss » Thu Aug 16, 2012 6:37 pm
ended up being both control and selector valve.
adamshuss
Post by adamshuss » Thu Sep 25, 2014 8:15 pm
It got a little better with the valve changes but the problem is still there. I've heard of welding the collectors then machining back to spec. Ever heard of this?
west25346
jd550 transmission
Post by west25346 » Sat Sep 27, 2014 5:32 pm
Talked to two JD service guys about the collectors being worn on inside diameter and neither could remember repairing the id of the collectors, just installed new sealing rings. Did you replace the rings on the pistons?
Users browsing this forum: No registered users and 244 guests
