350 blade model #
kycrawler
350 blade model #
Post by kycrawler » Mon Mar 12, 2012 11:22 am
I finally got my dozer in the shop to weld the blade frame up. but i need a few bushings and a new cutting edge, the problem is the serial number tag is missing and i cant look up parts. Does anyone now what the model number is? Its a 6-way blade on a straight 350
kycrawler
blade model#
Post by kycrawler » Mon Mar 12, 2012 2:59 pm
Never mind I found what I needed to know on Jd parts.com it does not list the bulldozer parts under 350, only under 350c for some reason!
andregrondin
Post by andregrondin » Tue Mar 13, 2012 10:32 am
Hi !
I was looking for parts on the tilt blade cylinder on my 350 straight and I couldn't find any in my book parts ( 921 ) so I went on th e 350c like you and tada !!!! there is the cylinder , anyone can confirm that they are the exact same cylinder ( I do not want to order parts and don't buy the right ones ) !!!!.
thank you
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
Post by Tigerhaze » Tue Mar 13, 2012 11:13 am
Usually when you do a model search on JDParts.com, the results are for the bare crawler. They also sometimes list the loaders that go with the bare crawler there as well but the best way to find your parts is to search for the dozer blade model number. I am not sure what that would be for a 350 but you can look at the serial number tag for the blade model number or someone on here should know.
CatD8RII
Post by CatD8RII » Wed Mar 14, 2012 7:58 am
From what I've gathered the blades are as follows
6300 inside mounted manual angle and tilt 6-way
6305 inside mounted all hydraulic 6-way
6310 outside mounted manual 6-way
If you search these model numbers they do come up, although I do not believe the blades got their own serial numbers, that would go off the machine its mounted on.
andregrondin
Post by andregrondin » Wed Mar 14, 2012 8:16 am
CatD8RII wrote:From what I've gathered the blades are as follows
Hi Thank you I will check that , I need seal kit for my tilt cylinder and one for the angling one as well but before I buy I want to make sure , what I found on my angling cylinder is : U10142T but I'm not sure a 100% it was dark and a lot of paint on the number so I will have to double check .
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
andregrondin
Post by andregrondin » Thu Mar 15, 2012 1:54 pm
Hi!
So far what I found on part # is that from catalog #916 of JD grid E3 section #15 page #21 the p/n for seal kit = AR105454
but when I went to e-bay to check availability and other info
it specify model 6305 ( blade model #) for crawler 1968 and up !
so my understanding is that it wont fit mine : which is a 1966 !!!
hum confusing here , anyone can help please .
http://www.ebay.com/itm/JD-Style-AR1054 ... 519c0f4dbd
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
CatD8RII
Post by CatD8RII » Fri Mar 16, 2012 7:04 am
On the angle cylinder, if you look at the parts book at line item number 18, it is a repair kit for machines built prior to 1968 , part number AU40286.
andregrondin
Post by andregrondin » Fri Mar 16, 2012 10:37 am
Hi !
Oh la la !!! d I look dumb ??? yep was right there in my face !!!
thank you CatD8RII !!!
I couldn't see the forest there was a tree in front of my sight !!!!
I check that now !!!!!
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
andregrondin
Post by andregrondin » Fri Mar 16, 2012 10:56 am
Hi !
P/n AU40286 = no where to be found ( search the net pretty much everywhere )
alos looking at AU14255 ( seal kit for the tilt cylinder ) .
anyone as a source ( hopefully Lavoy ) .
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
CatD8RII
Post by CatD8RII » Fri Mar 16, 2012 12:00 pm
Guess I should have checked first but the AU 40286 substitutes to AR99795, Deere can still get it, and there is some on ebay as well.
andregrondin
Post by andregrondin » Fri Mar 16, 2012 12:15 pm
Hi !
found the same thing !! p/n have changed fron AU40286 to AR99795
and the one for the Tilt AU14255 is now AR99792 both available at Mama Deere but that Deere Mama is what we call at lady of luxury !! price wise at least . on e-bay I found some as well but always try to buy from Lavoy first !
if Lavoy does not carry those then I'll try others .
thank you for the effort.
Dig in boy !!
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Users browsing this forum: No registered users and 244 guests
