Throttle problems
John K 1959
Throttle problems
Post by John K 1959 » Mon Mar 05, 2012 10:23 am
I have a 440IC that I have rebuilt the motor on and I am having problems setting the throttle/governor linkage. I have set it up per the service manual and the unit will idle and run fine but will not throttle up fully,I can only get about1600 rpm out of it and the governor is not even close to hitting the stop screw. If I shorten my linkage to the governor I can get the rpm up to about 2100 but then I can only get the engine to idle down to around 1000 rpm. I have tried changing the cinkage to the carb in conjunction with the linkage to the governor and I can not find any combination that works it just acts like I do not have enough throw or travel on the throttle. Anyone have any suggestions? The governor guts were replaced when I rebuilt the motor because of a bad bearing and one busted tooth on the gear. I also rebuilt the carb with a kit from Lavoy. When I set it up so that I have good RPM at full throttle the old girl runs great and the governor keeps plenty of power to her, just will not let it idle down. Anyone ever have this problem? I am probably overlooking something simple but it sure is frustrating.
Thanks guys. John
440IC Ser #458500
sbjuke
Hey john
Post by sbjuke » Mon Mar 05, 2012 12:26 pm
I sent you an e-mail regarding the 831 loader valve....juke
JUKE
DukeofDeere
Post by DukeofDeere » Mon Mar 05, 2012 10:11 pm
I will measure my throttle to gov. tomorrow for you.
As long as the rod down to the gov is at standard length all you need is to adjust the rod to the carb per specs.
Is your 440IC the old style throttle or the newer?
Duke
John K 1959
Post by John K 1959 » Tue Mar 06, 2012 12:42 pm
it s the newer style with the knuckle up by the dash. Thank you for your time
John
440IC Ser #458500
DukeofDeere
Post by DukeofDeere » Wed Mar 07, 2012 7:41 am
All 3 crawlers I measure vary from 16 1/8 to 16 3/8 of an inch overall length of the rod to the hole in the yoke.
Duke
John K 1959
Post by John K 1959 » Wed Mar 07, 2012 8:40 am
Duke thank you for your trouble I will measure and set mine accordingly and see what happens.
John K
440IC Ser #458500
DukeofDeere
Post by DukeofDeere » Wed Mar 07, 2012 10:55 am
No problem.
I hope that helps.
Duke
Users browsing this forum: No registered users and 231 guests
