Hello from England
I am having trouble locating a new clutch disc for my 450 dozer. I need a 275 mm dia. 30 mm 10 spline plate with springs in it. Our local JD dealer only has 32 mm 10 spline listed. Can anyone help with the correct part no please , or even a supplier. A used unit will do as I can reline it. It has been fitted with the wrong one in the past so can't use it again. It is the two forward and reverse type machine.
JD plant over here is not common and we don't have dealers for JD plant only agricultural.
Ken
JD 450 clutch
JD 450 clutch
Don't tell me I can't do it.
Users browsing this forum: Google Adsense [Bot] and 20 guests
