I need the size of the hose fittings on an 831 loader valve?
sbjuke
Post by sbjuke » Wed Feb 29, 2012 2:12 pm
need to know the size of the hose fittings on an 831 loader valve for my 440icd.........the original is bad and would like to replace it with a joystick and i can't get to it until snow melts at my camp.....wanted to order one now so i'm ready...........i meant to check it before i put it up for storage but forgot the sticky note that reminded me too remember.....lol
1/2" ? 5/8"?.......help...................thanks
JUKE
John K 1959
831 Control
Post by John K 1959 » Sun Mar 04, 2012 9:26 pm
SB the hoses to the cylinders are all 1\2 inch but there is a 3/8 fitting to the bypass valve and the return line is 3/4. You can get a parts catalog online free from John Deere that has all the hose sizes and lengths http://jdpc.deere.com/jdpc/servlet/com. ... ervlet_Alt. you will have to search 831. Hope this helps.
John
440IC Ser #458500
sbjuke
thanks
Post by sbjuke » Mon Mar 05, 2012 9:33 am
Thanks....i tried to get the manual there but it just comes up all symbols....like the pdf won't translate it.............does it do that for you also?
JUKE
John K 1959
Post by John K 1959 » Mon Mar 05, 2012 10:05 am
Juke I have the pdf file saved on my hard drive if you email me at john@knearem.com I will try to forward the file to you.
Oh also I do know where there is a complete control valve' used. I had to order one for parts for mine and the place called farmlandtractor.com says they do have one more. I think I paid 250.00 for the one that I bought. It was dirty and needed some new o-rings but definitely usable.
I do have a question for you, it looks like the yellow that you used on your machine just about matches what I used is yours the "new" John Deere Ag yellow? That is what I used from a farm supply store called Rural King.
Again hope this helps you out.
John
440IC Ser #458500
John K 1959
Post by John K 1959 » Mon Mar 05, 2012 10:11 am
Juke one other thing I forgot to mention is that they used 2 different controls on these loaders.The numbers are listed in the parts manual for both types. I am not sure if they both had the same size fittings, you will definitely want to check that our first.
John
440IC Ser #458500
Users browsing this forum: No registered users and 219 guests
