350 Track adjuster springs
xeagerx
Post by xeagerx » Sat Jan 07, 2012 8:20 am
:?: Greetings..Does anyone know where I can find a used adjuster spring for a 350? Are the springs on some other models the same? Mine is broke a couple of inches from top.
Thanks.....xeagerx :?
andregrondin
Post by andregrondin » Tue Jan 10, 2012 8:16 am
Hi !
I have no clue where but I'd also love to know !
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
MattE
Post by MattE » Tue Jan 10, 2012 11:24 am
I'm sure I'll take some flak for this.... But If they are only broke in one spot I've have had excellent luck in welding them. Trick is to use good filler and control cooling. Preheat to dull red in local area weld with a good high nickle rod and immediately bury in dry sand.
Just throwing it out there. I haven't had one break in the same spot yet, and I've done maybe ten or twelve different springs.
Shouldn't need to say this, but take the tension off first if you're going to give it a shot.
440 iron popper
Re: 350 Track adjuster springs
Post by 440 iron popper » Thu Jan 12, 2012 8:48 pm
xeagerx wrote::?: Greetings..Does anyone know where I can find a used adjuster spring for a 350? Are the springs on some other models the same? Mine is broke a couple of inches from top.
I know where there is a dozen of them. Same part number from 440 to 350 crawler. It is located in Quebec , Canada. Shipping could be high a bit for this kind of item! Did you try with Lavoy?
KenP
Post by KenP » Fri Jan 13, 2012 5:24 am
deleted
Post by Lavoy » Fri Jan 13, 2012 9:03 am
I should have one, and can get new as well.
Users browsing this forum: No registered users and 392 guests
