1959 440IC CRAWLER LOADER
cowman
Post by cowman » Sun Jun 11, 2006 6:37 pm
HELLO IVE GOT A 440 IT DRVES BUT LT SIDE IS HARD TO TURN PULLED ARM BACK NOTHING BUT PUT CLUTCH IN AND LET IT OUT SLOWLY AND WORK THE LT ARM IT WILL START TO CATCH CAN ANYONE HELP? :shock: :shock: :lol:
i have a 440ic gas crawler loader
hunter41mag
Post by hunter41mag » Tue Jun 13, 2006 11:48 am
I would first check adjustments to make sure sterring clutch/brake are setup properly. It sounds like the steering clutch is not releasing all the way or the brake is midadjusted or worn to much. The problem i had on my 440IC was the oil seal from trans/diff housing leaked onto my brake band/drum and it was doing the same thing yours is. If this is the case the final drive must come off for repairs.
Don
440IC
