exhaust question
mikeintn
exhaust question
Post by mikeintn » Sat Nov 12, 2011 8:48 pm
Getting ready to put the hood back on my 350b and not sure if I'm missing something [ it was all apart when I got it ], they are an extension bolted in the hood I'm sure that the top pipe would clamp on it, question is when the muffler sticks up inside the extension in the hood is there something that seals it, the inside of the extension is bigger then the muffler looks like exhaust would leak under the hood if it wasnt sealed, I looked in the parts book but dont see what I'm missing, if I am missing anything :?
Michael
Post by digitup2 » Sun Nov 13, 2011 7:41 am
I have never seen anything that would seal in between the two even my 350D had it straight from the out put port on the muffler to the exhaust pipe support built into the hood.Dozers take a real shaking over a life time and several things are taken to the max like frame ,exhaust mount ,no fuel guage [Till later years and still get beaten to a pulp in a couple of years of sloshing ]even battery's have 30% less life expectation in a dozer than even a excavator I find small dozers shake the led plates right out of a battery.I just installed gell cell in my new 450J to see if they will last longer .I also find that a smaller dozer takes more of a shaking than a larger dozer takes I have never shook a battery apart in my 750D or 850CII but my little old 350D wide track had several new battery's installed over the years so shake is a significant enemy of a smaller dozer I feel .Digitup.
mikeintn
Post by mikeintn » Sun Nov 13, 2011 5:49 pm
Thanks digitup2, thats good news, that mean I'm not missing anything :D
Michael
VT350C
Nope
Post by VT350C » Wed Dec 07, 2011 9:14 pm
Nope, the small pipe off manifold is smaller than the extension that clamps to hood...made to break-away if you hit a branch (I did;-)
John Deere 350C with 6-way and winch
John Deere 302A Loader, Backhoe and 3pt.
John Deere Backhoe 9250A - 4pt frame mount
Kubota B7100 HST with Loader
MEP002A Military Diesel Generators
MEP003A Military Diesel Generators
mikeintn
Post by mikeintn » Wed Dec 07, 2011 10:47 pm
I am confused, I think :? lol, does the main top pipe [ where the smoke comes out ] clamp to the extension that bolts to the hood, or does it connect to the pipe coming out of the muffler? I'm sure I'm just not getting it :oops:
Michael
Post by digitup2 » Wed Dec 07, 2011 10:49 pm
exhaust pipe hooks to the hood.Digitup.
VT350C
I think I may know what you're talking about
Post by VT350C » Wed Dec 07, 2011 10:51 pm
If you detach your muffler extension...the wider pipe that clamps to the hood...and you shimmy your air intake off, you should be able to remove the entire hood...
Once you do that, you should then see your exhaust manifold, attach to your muffle and then that is unified to a one foot exhaust...
BUT, if this one foot extension has been cracked off (I did this!), it will be a wobbly 1 foot piece! It won't be connected to the exhaust! And it's never supposed to be connected to the extension that is part of the hood...
You CAN have this tack welded back to the muffler and use muffler puddy or a special caulk that is used to seal hot joints...It's a bit of a hack, but a guy did this for me and it's 100%...So the one foot section should be welded to the muffler that is clamped to the manifold...
mikeintn
Post by mikeintn » Wed Dec 07, 2011 11:16 pm
Thanks Digitup, thats what I was thinking just wasnt sure, now I got it :D
Michael
77 Ford
Post by 77 Ford » Thu Dec 08, 2011 8:49 am
My 450c is just like what you are describing. I wondered if having the larger pipe as part of the hood over the smaller pipe of the muffler would help prevent water from running down the stack into the top of the motor.
Any rain running down the walls of the stack would miss the muffler and therefore the top of the motor completely.
JD- 450C track loader
Serial #208336T
mikeintn
Post by mikeintn » Thu Dec 08, 2011 9:01 am
Thats a good point also ford 77, I see what your saying.
Michael
Users browsing this forum: No registered users and 345 guests
