2010 oil pan removal-- HELP?
dlplost
Post by dlplost » Sun Nov 06, 2011 3:46 pm
OK, 2010 Diesel, Spun bearing, got all the OIL pan bolts out, pan will not come off.....Any suggestions??
counted 21 bolts out, same as the book shows....???
1963 John Deere 2010C, Diesel, 6 way PAT Dozer
1950? John Deere MC
1952 Ford 8N
1950 Ford 8N with Sherman over/under drive and homemade Backhoe & Loader
Did have a 1956 IH TD-9 Drott Skid-Shovel, "Smokey"
Post by jtrichard » Sun Nov 06, 2011 6:43 pm
if your sure you have all the bolts out take a wood chisel and drive it in between the pan and the block at a rear corner of the pan
dlplost
Post by dlplost » Mon Nov 07, 2011 1:21 am
Yea all the bolts were out, The Kid came by and wailled on it with a hammer and chisel, it finally let loose.
Looks like the last person to put it on used some sort of epoxy sealer on both sides of the gasket, it's very hard, basically ripped the gasket in half pulling the pan off.
Thanks..
1950? John Deere MC
1952 Ford 8N
Users browsing this forum: No registered users and 217 guests
