Post
by JD440ICD2006 » Mon Jun 27, 2011 9:46 am
Ed,
I enjoy all of the pics, please keep them coming.
Chuck W.
440 iron popper
Post
by 440 iron popper » Sat Jul 02, 2011 10:13 am
A lot of work there! Do you have some help on your project ? For me, Not many people offer their help but they ask when it will be fixed because they have something to clear on their land!
The 2-53 will keep you busy for a while! Keep the pics coming.
whiteclipse16
Post
by whiteclipse16 » Sat Jul 02, 2011 10:41 am
Thanks for the comments guys. I have a little help. My dad is a good fabricator so if something needs welding or what not I go to him. It's fun and def. Time consuming. People don't realize the little things that you have to do like polishing gears and tapping holes. They think its sand blast and paint. Oh well hopefully I'll finish it in a few months.
Ben
Post
by mini kahuna » Mon Jul 04, 2011 1:21 pm
looks like you have your hands full,it's great to see someone saving a machine from the scrap yard.
looking good!!!!!
whiteclipse16
Post
by whiteclipse16 » Mon Jul 04, 2011 8:11 pm
Thanks mini,
Yes we've got to keep them alive or else they'll be gone forever. Plus its too expensive to buy a newer one haha.
Ben
whiteclipse16
Post
by whiteclipse16 » Mon Sep 26, 2011 6:40 am
whiteclipse16 on Tue Jul 16, 2013 6:37 pm, edited 1 time in total.
Ben
Post
by JD440ICD2006 » Mon Sep 26, 2011 7:20 am
Looking good!!
The tracks look good from the pics. Still some meat left on the grousers and the rails do not look nearly as worn as I have seen.
The toughest part for me on the rebuild is that part of me that says "hurry up" argues with that part of me that says "do it once and do it right." The "do it right" part wins most of the time, the reason I have been working on mine for so long.
whiteclipse16
Post
by whiteclipse16 » Mon Sep 26, 2011 8:19 am
Haha, I completely agree with you 2006. I want it done so bad, but then I say the same thing, "It'll be so much nicer if the extra time is taken and its done right."
My grandpa said he had it re-pinned and bushed before he quit running it, that's partly why they're so stiff. I'm going to get some diesel on them and work them some before re-installing.
The bad part is, the undercarriage is so rusty that all the bolts are just breaking, even with heat.
I'm going to get the other blade mount off and flip it over to get to all the bottom rollers off to inspect them. The rollers and motor should keep me busy through winter.
Thanks for the comments.
Ben
shinnery
Post
by shinnery » Mon Sep 26, 2011 7:01 pm
Well in your spare time tell us a little about "HY47N". Curious minds want to know? Looking Good.
whiteclipse16
Post
by whiteclipse16 » Tue Sep 27, 2011 6:10 am
It took me a second to figure out what you meant by the HY47N.
That would be my Dad's 48 Ford coupe. It's probably his favorite car. The unique part about it is that it has a 350 chevy with 4-speed and related chevy running gear. It definitely turns some heads.
Also in the garage, but not pictured is a 55 Chevy 210 (Also my Dad's).
69 Mustang Coupe (Mine) and my brothers work in progress, 68 MGB.
On the tractor side we have an 8N Ford (now mine, was my grandpa's) an Allis Chalmers WC (My Dad's, was my great grandpa's) and a Super A.
It seems we always have something were working on, but it sure keeps me busy and my mind somewhat clear.
Ben
andregrondin
Post
by andregrondin » Sun Oct 02, 2011 5:31 pm
HI !
very nice work you are doing on this baby !
keep up the good work I"m sure it will end up very well .
Dig in boy !!
J-D 350 straight 1966
model # = T4F3D
serial # = 08883T
J-D 690-B 1980
model # = D690B
serial # = 007364T
Mack RB688S 1990 dumper
whiteclipse16
Post
by whiteclipse16 » Fri Dec 02, 2011 8:32 am
Hey guys,
I've run into a bit of a problem. I got the undercarriage tore nearly completely down (pics below). I took some of the rollers off because 1. they are shot and 2. they are full of dirt inside.
I got one roller to come apart and cleaned up but the others I've not had the same luck. I'm trying to pull the end caps off because they are packed full of dirt. Do you guys have any good ideas for getting those end caps off. The one I got apart I just used a pry bar and smacked the shaft with a hammer and they came off. The others are on there good though, my dad even made a puller and it wouldn't budge them.
Ben
440 iron popper
Post
by 440 iron popper » Sat Dec 03, 2011 5:43 pm
Hi Ben,
Your undercarriage is more advanced than mine
Nice Work! About these bolts from another century... How easy was the removal?
For the rolls, I would change them. Deere have them but pricy. I bought one... 285$ Ouch! and found out a bunch of Used ones. Total for 8 rolls= less than one from Deere!
Good pics! Good Work!
whiteclipse16
Post
by whiteclipse16 » Sat Dec 03, 2011 11:13 pm
Thanks for the comments iron popper.
The bolts were a pain, had to heat most of them and then there were about 5 per side that broke. (Those are the bolts that hold the rock guards that is).
The bolts for the rollers came out easier but some still needed heat. Didn't break any of those but one stripped the threads out when it was coming out.
Biggest road block now is the fact that I can't get those end caps off on the rollers. The seals are still good and the bushings are good, I just want that dirt that's packed in there out.
Hopefully someone can chime in with a good suggestion.
Motor is nearly ready to get a coat of primer. Need to wire wheel a few more spots and tap a few more holes. The undercarriage will probably be done until spring since it's outside, but really all it needs is sand blasted and some welding done on the rock guards.
Hopefully you've got some time at home and are making progress on yours.
Ben
Users browsing this forum: No registered users and 104 guests
