Towing a dead 2010C
dlplost
Towing a dead 2010C
Post by dlplost » Mon Sep 19, 2011 5:46 pm
2010C Diesel HLR
Dead, we think it has a spun main bearing.
OK we got a dead 2010C out in the woods, we need to tow it in.
If we shift it into the "TOW" position, exactly what does it do?
Problem is this machine is it is "stuck" in the 1-2 position.
In order to change it, we have to open it up and manually move the gears to change it.
The guys have moved it about 6 feet and it stoped, won't move any more.
I think we need to open it up and shift it to "tow".
Thoughts, comments, opinions?
1963 John Deere 2010C, Diesel, 6 way PAT Dozer
1950? John Deere MC
1952 Ford 8N
1950 Ford 8N with Sherman over/under drive and homemade Backhoe & Loader
Did have a 1956 IH TD-9 Drott Skid-Shovel, "Smokey"
Post by jtrichard » Mon Sep 19, 2011 6:35 pm
yes i would say i have 3 2010s and have never had any of them in tow i think that is neutral good luck you bringing her back to life? If the steer clutchs are good you can block the levers up to where it releases but not to where the brakes apply and she will move
dlplost
Post by dlplost » Tue Sep 20, 2011 9:58 am
Looking in the book, it looks like we're fighting the gears in the tranny.
It looks like the "tow" position puts both shift collars in "neutral", so none of the gears are connected together.
OK, thanks..Will try blocking the levers like you suggested, if that won't get it we'll have to open it up and get it to "tow" position.
1950? John Deere MC
1952 Ford 8N
Post by Tigerhaze » Tue Sep 20, 2011 12:36 pm
Technically you are supposed to put the dash shifter to "tow" if you are going to tow any significant distance- however I have towed my 2010 with HLR short distances in neutral on the HLR shifter but left in gear on the dash shifter. Are you sure that something else didn't happen like the brake pedal locked in place?
dlplost
Post by dlplost » Mon Sep 26, 2011 7:45 am
Well, we got it down to the garage.
We opened it up and shifted it to "TOW", and yes that does put both shift collars into "neutral" so the gears don't spin when you tow it. If you figure the gear ratios, to pull it at one mile an hour it has to spin the gears at something like 2500 rpm.
It took the winch, a Ford 8n pulling and an MC pushing to get it up the small hill (50 ft altitude)in the road, then the MC pushed it down hill (250 ft altitude) all the way to the garage - total distance just under a mile.
We think the pressure valve in the oil pump is stuck open, drop in oil pressure, spun bearing.
1950? John Deere MC
1952 Ford 8N
dlplost
Post by dlplost » Mon Jul 23, 2012 10:56 pm
OK, well here we are almost a year later..
Yes it had a spun Rod bearing.
The plunger in the oil pump was STUCK open.
I had to remove the oil pump to get the plunger out...
Got the Rod bearing and the oil pump plunger both fixed.
Now All I got to do is remove the injection pump, time the oil pump, then reinstall and time the injector pump.....
OK, so now I need to find the little crush washers for the banjo fittings..
Book says they are "T 11292 T" gaskets.
Any body got any?..Gonna try NAPA in the morning..
1950? John Deere MC
1952 Ford 8N
dlplost
Post by dlplost » Sat Aug 04, 2012 5:51 pm
Sucess!!
It's alive again.
Took all day bleeding and cranking to get all the air out of the lines, but it finally started. (took my time, went out once an hour and cranked on it, then let it sit and cool/charge the batt.)
Ran it for about 30 min a varying speeds.
Got 30psi oil press up to running temp at idle, 50-55psi at full power.
all bearings sound good, no noise/no knock.
Almost hated to shut it down...
now all I got to do is put the skidplate and blade back on..
1950? John Deere MC
1952 Ford 8N
Post by Tigerhaze » Mon Aug 06, 2012 9:04 am
Great feeling, isn't it ;)
Users browsing this forum: No registered users and 176 guests
