john deere 350 track loader
eraben56
Post by eraben56 » Wed Aug 24, 2011 6:35 am
gentlemen, first let me say what a neet sit this is. people helping other people. i am impressed. i just purchased a 350 crawler gas loader for 5 grand. under carriage looks almost new. starts and runs like a kitten. after i got her home i ran it for a couple of hours pushing trees out. now the problem. when using the reverser there is a long hesitation before it will start to move, in either direction. from what i have found there is a pressure switch and a filter. no clue where they are located. it is full of oil. clutch works fine. no strange noise from transmission or reverser. any help is greatly appreicated.
Post by Lavoy » Wed Aug 24, 2011 8:07 am
I would invest in a parts and service manual before attempting to change or adjust anything. There is an adjustment as far as reverser shift speed, don't remember how to do it though.
I would drain the reverser and replace the filter first if I was you.
KenP
Post by KenP » Wed Aug 24, 2011 12:44 pm
deleted
eraben56
Post by eraben56 » Thu Aug 25, 2011 5:23 am
KenP wrote:As Lavoy said, you want to start by putting a fresh filter and fluid change in your reverser.
There is an adjustment on the reverser, accessed from the bottom of the crawler, that adjusts how fast the reverser engages the forward and reverse clutch packs after you move the reverser lever.
Everything is well described in the Service Manual for your machine, SM-2063.
The Service Manual should be your first purchase for your crawler.
thanks to both of you, i am shopping for a manual. i will up date asap.
Post by JD440ICD2006 » Thu Aug 25, 2011 6:01 am
Welcome to the crawler world. I agree that this site is about the best. Lavoy continues to do a great job keeping it free of clutter, spammers, and people starting trouble that do not need to be on here.
"We do not push each other around, we just help each other PUSH other stuff around." :lol:
KenP
Post by KenP » Thu Aug 25, 2011 7:26 am
deleted
eraben56
Post by eraben56 » Sat Aug 27, 2011 3:07 am
KenP wrote:Make sure you are positive what model your 350 is before shopping for a manual. Based on your description as a 350, SM-2063 is the right service manual. If, on the other hand, the machine is a later version, such as a 350B or 350C model, you'll need a different manual.
If you're not sure, you can check the serial number against the list on this forum and confirm.
Deere will sell you the manual for your machine on-line. You can get it as a download, on a disc, or as a hard printed pub.
ken & lavoy i feel like a dumy. after a little research i i found i now have a 450 track loader. i wish i would have listed that info in my first request for help. it is a 4 cylinder gas. i see 350's did not have a 4 cylinder in them. also where can you locate the serial number?
Users browsing this forum: No registered users and 358 guests
