2010 track master pins
jhv1050
Post by jhv1050 » Tue Aug 16, 2011 8:33 am
In the process of steerinc clutch rebuild on my 2010 dozer, I have found what I think are the master links on the track. one pin has the dimpple in the center and then right next to it is a pin with a mushroom head. why would this be ,and which one should I try to remove?
Thanks,
A man can't have too many tractors!
2010 crawler/dozer
4010 diesel
1050 utility diesel
706 international
154, 184, cub lo-boy
Post by Lavoy » Tue Aug 16, 2011 8:53 am
The mushroom head pin should have a snap ring on the other end, that that one out if it does.
Pammark
Post by Pammark » Mon Aug 22, 2011 11:17 am
The master pin has the mushroom head and C-clip, like Lavoy said. My pin mushroom head also was not round, but flattened on one side to fit in the groove to keep from spinning.
Look at my site "2010 repair" and see how I removed the pins. I derailed the tracks, layed them on the side and juiced up with penetrating oil. Get a punch the correct diameter (about 3/4 inch) and drill a 2 X 4 block to hold the punch upright. Hammer away safely with a sledge.
Mark
JD 2010 Crawler with Loader
201 track pin removal
Post by JD440ICD2006 » Mon Aug 22, 2011 1:36 pm
All credits to "PAMMARK" for the following:
I have been juicing up the mastepins for the last week. My neighbor (a machinist) made me the 3/4" punch out of hardened steel. I drilled a 3/4" hole in a 2X4 chuck directly over the pin location. C-clamp the board, insert the pin and whack away.
About 3-4 good swings with the sledge and . . .
There she goes. The master pins popped out, Slicker than You Know What. (Chuck thinks it has something to do with an owl!) The 2X4 is thick enough to support the punch and keep the pinkies out of the way. The C-clamps hold the board directory over the taget. All safe and sound. And I didn't even learn a new language that would blush a sailor.
Mark[/quote]
jhv1050
Post by jhv1050 » Tue Aug 23, 2011 5:14 am
Thanks for the help.
2010 crawler/dozer
4010 diesel
1050 utility diesel
706 international
Post by Tigerhaze » Tue Aug 23, 2011 11:06 am
Pammark wrote:Get a punch the correct diameter (about 3/4 inch) and drill a 2 X 4 block to hold the punch upright. Hammer away safely with a sledge.
After removing 2010 master pins the more traditional way (i.e. scaring the crap out of the assistant holding the pin), I think I will try the method shown. It looks like it works really slick.
Post by Lavoy » Tue Aug 23, 2011 2:36 pm
Where the hell did you find any body dumb enough, I mean willing, to hold the punch? :lol:
Post by Tigerhaze » Tue Aug 23, 2011 4:10 pm
My brother :lol:
I actually had him hold it with tongs at a relatively safe distance but it is pretty hard to get a straight solid shot on the punch with the sledge (holding it with tongs) so I will go with Mark's suggestion in the future.
Post by Lavoy » Tue Aug 23, 2011 4:38 pm
SOOOOOO, how much beer did that cost ya?
jhv1050
Post by jhv1050 » Tue Aug 23, 2011 9:35 pm
Was the beer ( also known as LIQUID STUPID) before or after the job was done?
2010 crawler/dozer
4010 diesel
1050 utility diesel
706 international
Users browsing this forum: No registered users and 164 guests
