1010 eccentric pins on the loader, are they easy to remove?
bingles
Post by bingles » Sun Jul 31, 2011 6:06 pm
I bought replacement motor for my 1010 and I am about to start removing my old motor but to get to the motor I need to remove the loader. The service manual shows to remove loader, cab and controls as one. I dont think I can do this in my gravel driveway and no sturdy tree near by. So I was thinking it would be easier to remove the eccentric pins that hold the loader to the tractor and pins on the lift cyl and lift it up and away with a tripod I have. DO those pins come out easy? Will it be easy to replace when done?
Does this sound like a good plan or whats easiest?
Brian
JD1010C My first John Deere
430deere
Post by 430deere » Sun Jul 31, 2011 7:21 pm
If you take a look through some of the "Show & Tell" discussion threads, you will see a gentleman that has removed the engine from his crawler while the loader was still attached. I can say I have never had any experience (yet) removing an engine from a crawler (only from 2-cylinder tractors), but you are asking at the right place to get some really good feedback. Look forward to hearing from some more experienced crawler buffs on this one. Have fun with the project, and be safe!
40U Orange (CJ 108)
320U Yellow
420T Yellow
420U Yellow
420W Orange
420W Yellow
430U Yellow (CJ 265)
730D STD ES
1010 ICD w/810 Loader & 50 Backhoe
3010 Industrial Wheel w/720 Loader (Gas)
3010 Industrial Wheel w/Ldr. (Gas)
Post by jtrichard » Mon Aug 01, 2011 12:15 am
i would say you have the right idea since you cant run it I would do it that way youll have to figure a way to block the arms up and pull the crawler back
KenP
Post by KenP » Mon Aug 01, 2011 4:47 am
deleted
bingles
Post by bingles » Thu Aug 04, 2011 7:45 pm
[img http://i1178.photobucket.com/albums/x37 ... MG0384.jpg ]
[/img http://i1178.photobucket.com/albums/x37 ... MG0385.jpg ]
I got the motor out here is the setup I went with, Worked great...
kinda redneck setup, but got do what you got to do... :)
Nice setup kenp!!!
thanks
BRian[/img]
bingles
Post by bingles » Thu Aug 04, 2011 7:47 pm
gg
Post by jtrichard » Thu Aug 04, 2011 8:55 pm
looks like it was made to do just what you did with it. work with what you have is always fun
Users browsing this forum: No registered users and 193 guests
