1960 jd 440 crawler loader
kstivers
Post by kstivers » Thu May 18, 2006 6:30 am
I need to find a website to download tech data for my jd 440 loader. also
the tranny wont go into gear while eng. is running. i know the tranny is good because i can jam it into 1st when i idle it low. is there a clutch and pressure plate set up like there is with a regular vehicle with a standard system.
moveitall haulin
Howard Yoder
Post by Howard Yoder » Thu May 18, 2006 7:35 am
Yes it is a regular clutch set up. Do you have a reverser on it? If you keep jambing it into gear you won't have a good tranny for long. More than likely if it has been sitting for a while the clucth is rusted to the flywheel. If you do have a reverser it will have a lever on the left side of the dash and you can put this in nuetral and put it in gear and use it like this for a while to see if the clutch breaks loose but more than likely you will have to pull the engine. Good Luck
kstivers
Post by kstivers » Sun May 21, 2006 9:16 am
I dont rmember a lever on the dash, I will look when I get back home. there is a lever on the left side of the shifter, mounted on the tranny. the tranny is a 5 speed with reverse. I got a quote to replace the clutch and pressure plate of about $800. It sat up for 8 years before I got it. Every thing eles works great.
moveitall haulin
shinnery
Post by shinnery » Sun May 21, 2006 12:55 pm
The reverser lever will be on the side of the dash, above the clutch pedal if so equipped.
kstivers
my crawler
Post by kstivers » Wed May 24, 2006 11:26 am
Checked and no reverser. it has the shift rod running throught the dash, not connected, i suspect that was a standard issued part. I went ahead and took it to the repair shop. he is going to pull the clutch assmbly and have it rebuilt. parts will be about $350. John Deere has the clutch parts but the clutch disk alone is over $500.
I also need to find a cheap place to buy trac treads. JD wants $50 a piece
moveitall haulin
Post by Lavoy » Wed May 24, 2006 1:23 pm
I have engine clutch kits for $200. I may have a set of used pads depending on what style you want.
kstivers
Post by kstivers » Wed May 24, 2006 4:17 pm
I dont know if I replied to the correct post so here goes again:
what is included in the kit, how long to ship to florida and how much is shipping?
moveitall haulin
Post by Lavoy » Wed May 24, 2006 6:19 pm
Kit in includes new disc, rebuilt pressure plate, and new throwout bearing. If you want new pressure plate, add $40. I would guess freight at about $20.
kstivers
1960 440
Post by kstivers » Mon May 29, 2006 6:21 am
Lavoy, I called the shop and they have already replaced the clutch. they didn't get the new on there is a place here in jacksonville that rebuilds them so they went that route. He onoly need to find a bearing now.
moveitall haulin
kstivers
1960 440
Post by kstivers » Mon May 29, 2006 1:44 pm
Lavoy, do you have a power shaft assembly?
moveitall haulin
kstivers
60 crawler
Post by kstivers » Fri Jun 02, 2006 5:17 am
crawler is up and running. right side trac is loose. tried putting greese in but its not moving. must be missing something here
moveitall haulin
