450B left steering problems
Johnstas
Post by Johnstas » Tue Jul 26, 2011 5:04 pm
Wondering if someone know what is going wrong when I pull on the left stick and nothing happens. Does this mean the steering clutches need replacing ? It looks like the brake band is okay. Any advice would be appreciated.
Post by Tigerhaze » Tue Jul 26, 2011 5:15 pm
It may just mean that steering lever is way out of adjustment, especially if you are getting nothing after fully pulling the lever (i.e. when the brake band should be applied). I would go through the adjustment procedure in the manual first and see if it makes a difference.
Johnstas
steering problem
Post by Johnstas » Wed Jul 27, 2011 1:26 am
I adjusted the left clutch back the way that it was. Now I get right steering, but the left is still very little. I do have bushing wear in the sticks.
should I just try to adjust a little bit of clutch at a time ?
Post by jtrichard » Wed Jul 27, 2011 1:21 pm
do you have power to both tracks? if so than you dont have a bad clutch. A bad brake or adj.or linkage is where to look
Users browsing this forum: Google Adsense [Bot] and 322 guests
