420 set screw on fan blade
tzbmcp
Post by tzbmcp » Fri Jul 15, 2011 8:30 pm
minimal torque on fan blade set hex screw and it broke right off. options?
Willyr
Post by Willyr » Fri Jul 15, 2011 8:44 pm
Take a look at this diagram and tell us what you broke.
former owner of a 1956 420c
Willyr
Post by Willyr » Fri Jul 15, 2011 9:22 pm
More than likely you will have to drill the center of the bolt warm it up with a torch then use an easy out on the hot surface and try to remove the bolt.
Post by Lavoy » Sat Jul 16, 2011 12:26 am
Set screw will be hard to drill. At this stage, I would pull the radiator so you have room to get at stuff. Weld a nut to the broken off set screw, and it should back right out.
tzbmcp
Post by tzbmcp » Sat Jul 16, 2011 7:17 am
thanks. radiator is off.
tzbmcp
Post by tzbmcp » Sat Jul 16, 2011 7:25 am
is set screw a specific part or might i be able to find replacement at hardware store?
Post by Lavoy » Sat Jul 16, 2011 6:29 pm
Might find it at a hardware store, it is just a 5/16" coarse thread set screw, length you can figure out. In a pinch, you can use a bolt.
tzbmcp
Post by tzbmcp » Sat Jul 16, 2011 7:23 pm
thanks much, found near exact match at local ACE hardware. got bolt out nearly effortlessly using Alden Drill Out - highly recommend this as I've never been a fan of easy out. this thing has drill bit on one end and extractor on other. very easy to use. swear i dont work for the company.
Users browsing this forum: No registered users and 255 guests
