Need a PTO Drive Shaft for JD 350
Just wondering if I can buy a PTO "powershaft" attachment for my JD 350. If anyone knows of where this assembly can be purchased either new or used, please let me know.
Thanks,
Nick C
Algonquin, IL
Thanks,
Nick C
Algonquin, IL
- Willyr
Any farm tractor dealer can make you a pto drive shaft. You will need to know how much torque you require, or to tell them your application. Then with your implement attached you want to know the distance between the tractor PTO shaft and the implement shaft (you want the arms to be horizontal to the ground, the shortest distance on a tractors 3 point hitch). The inbetween shaft needs to be "sized". Too short the ends of the drive shaft will seperate, too long and you will damage the drive shaft universals.
former owner of a 1956 420c
- Willyr
Actually over turning a generator will change the cycles of the frequency. Instead of having 60 cycles per minute you may end up with something around the upper 70's? This is why some engine driven generators have a frequency indicator.
Users browsing this forum: No registered users and 171 guests
