Bush Hog Shear Pins
JAY AND EBBEN
Bush Hog Shear Pins
Post by JAY AND EBBEN » Wed Jul 13, 2011 6:51 pm
We have a bush hog squealer (4 foot). We need help with what to buy for shear pins and where they go. I THINK they would go on the drive shaft, but then again have no idea. Any help would be great...
Thanks,
ebben
We're not bottom feeders, we're salvage experts!
Willyr
Post by Willyr » Wed Jul 13, 2011 9:17 pm
Stop using shear pins and use a replacement torque clutch. Far better and less maintenance.
$129 at Tractor Supply
http://www.tractorsupply.com/agricultur ... ft-0271203
former owner of a 1956 420c
Post by JD440ICD2006 » Thu Jul 14, 2011 8:20 am
I have a 6 foot King Kutter 3 point hitch (single rear caster wheel).
I buy Grade 2 bolts with nuts and lock washers (shear pins) for less than $.50 each set. I carry two wrenches in my tractor battery box and several shear pin sets. I use a new bolt if I need something to get the piece of the old bolt out.
I seldom shear a pin and it is always when I forget to raise the mower and hit a hump of dirt.
It works and the cost could not be better unless the bolts were free.
If I sheared 4 bolts a season ($2.00), it would take over 60 years to break even, not counting the few minutes to replace the shear pin.
Post by Lavoy » Thu Jul 14, 2011 10:14 am
They will typically be on the yoke that hooks to the tractor PTO. Several different styles are seen, you will need to look closely at the yoke and you should see the shear pin. They are typically just a standard bolt and nut.
Post by JD440ICD2006 » Thu Jul 14, 2011 10:22 am
The shear pin location on the King Kutter is the connection of the rear of the PTO shaft to the shaft of the gear box. Very easy to get to in the event of a sheared pin.
Not sure where they may be on others but likely in the same area.
JAY AND EBBEN
Post by JAY AND EBBEN » Fri Jul 15, 2011 7:26 pm
Thanks for your help! We found where the pins go and will give the bolt idea a try first. The torque box may work well if the pins go flying too often.
Ebben and Jay
CELSESSER
Post by CELSESSER » Sat Jul 16, 2011 9:25 am
Make sure that you get a bolt that fills the hole as a smaller bolt that has some slop will shear much more quickly. I run a 6' king kutter with a 75 horse tractor and it takes 1/2 inch bolts. I just use the bolt to drive out the piece left in the center shaft after aligning the holes, it doesnt usually bugger the threads much. then I put just a nut on and bugger the threads with the hammer to keep the nut on. Takes me 5 min at the most. I agree with 440, tryin to chop dirt is almost always how I shear one.
Chuck
JAY AND EBBEN
Post by JAY AND EBBEN » Mon Jul 18, 2011 9:54 pm
"Make sure that you get a bolt that fills the hole as a smaller bolt that has some slop will shear much more quickly."
We found that one out the hard way :D ... It didn't even make it six feet before it sheared!
ebben
Users browsing this forum: No registered users and 158 guests
