New Implements case hoe
gerald
Post by gerald » Thu May 26, 2011 8:04 am
I found this not far from my new home for $1100. I couldn't get my wallet opened fast enough. It was set up on a trailer cat that is a small remotecontrol 4 cyll dover for moveing manufactured homes . The owner built 4x4 heavy tubing frame on the back with a seat for quick detatch. I figure about 2 hours work an it will be permanent on my crawler. The bucket ls 10 wide inches very good shape. It will be graet for post holes and setting iron beams for my shop.
gerald
Post by gerald » Thu May 26, 2011 8:07 am
I for got to resize the pic Sorry Gerald
JWB Contracting
They are a nice little hoe
Post by JWB Contracting » Thu May 26, 2011 12:11 pm
We converted one of these to mount on our 350C widepad dozer machine as the deere hoe is too heavy to do any dozer work when mounted.
We did have to put a larger hydraulic pump on as the hoe was fairly slow acting with the dozer only pump. After the pump change it worked very well. It had enought power to push the crawler around to reposition for digging or forward to continue a trench.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
gerald
Post by gerald » Thu May 26, 2011 10:32 pm
Jwb. My 350 stright crawer has 23 gpm pump. With the 93 A hoe. I think the small case hoe would be made for open circut hyd sys .
shinnery
Post by shinnery » Fri May 27, 2011 11:39 pm
Do you know what model of Case hoe that is? It sure looks a lot diff. from the #33 hoe on my 580CK. Just wondering.
gerald
Post by gerald » Sat May 28, 2011 7:16 am
Model 3J4121 case it has 8 inch bucket , It will be good for planting trees ,an setting fence polls. The crawer came with 93 A hoe 24 inch bucke That is burte and to heave for counter weight.
Users browsing this forum: No registered users and 176 guests
