Transmission filler bolt
Tateremtp
Post by Tateremtp » Wed May 18, 2011 8:14 pm
Any ideas other than PB blaster on getting that bad boy loose. Is there a speacial tool, socket or prayer taht has to be sued or said?
Post by Lavoy » Thu May 19, 2011 8:57 am
Which crawler are you working on?
Tateremtp
Post by Tateremtp » Thu May 19, 2011 4:47 pm
40 c the filler cap is in the right foot rest area with a square bolt head. right behind the brake pedal.
Post by Paul Buhler » Thu May 19, 2011 6:37 pm
Hi: I just checked my 420c. The plug has a 5/8" square head. I used a 5/8" open end wrench on it and had good solid purchase. To try and help with your challenge, I then took a crow bar and wedged it between the foot well and the box end of the wrench and slid a 4" socket extension behind it to give me a fulcrum. I had lots of leverage and could probably have tapped on the head with a hammer while applying torque to get it moving. My plug appears slightly tapered, so getting it moving a bit will mean that the task will get easier with each partial revolution. Hope this helps. Paul
Tateremtp
Post by Tateremtp » Thu May 19, 2011 6:47 pm
Thank you alot. I will try that combination of tools in the AM. Chad
Post by Ray III » Thu May 19, 2011 7:55 pm
If it is really stubborn, you can buy a double square socket which will let you put an extension on to get the ratchet up where you can pull on it.
Tateremtp
Post by Tateremtp » Thu May 19, 2011 10:10 pm
Never thought of that one. Thanks alot.
Tateremtp
Post by Tateremtp » Mon Jun 06, 2011 10:22 pm
Thanks to all for the advice. I used a 5/8 wrench, pry bar, PB blaster and a prayer and it gave up the fight. Now going to put in 6 1/2 qts of gear oil and get to pushing some dirt.
Users browsing this forum: No registered users and 176 guests
