1010 crawler problem
Ricky Sims
Post by Ricky Sims » Mon May 01, 2006 2:45 pm
I bought a 1010 crawler that someone else had been working on and it will not pull on the left side. We took it apart and found that the short axle that goes thru the cutting clutch into the ring gear and pinoin goes thru too far past the splines on the shaft where it goes thru the pinion. The person I bought it from said he put in a ring gear and pinion, is there a wrong one that will bolt in, or do I need to disassemble the other side and look in there. According to the parts manual 420,430,440, and 1010 rearends are the same, unless my information is wrong. How can I dertermine if it is the right one?
Post by Lavoy » Mon May 01, 2006 3:56 pm
It sounds more like the the ring gear carrier has the splines worn out of the carrier.
JD430C
Post by JD430C » Mon May 01, 2006 4:09 pm
rick, thats a common problem on the 1010s. u have two options-change the ring gear carrier or shorten the axle. my dad bought a 1010 and it took a while for use to figure out the splines were gone. we ended up having a machine shop cut 2 inches off the shaft otherwise we would have had to take the tranny out. as far as i know its still working.
andrew
Ricky Sims
Post by Ricky Sims » Tue May 02, 2006 6:28 am
Sounds like I need to find a ring gear carrier, do you know where I can find a used one ? I would rather replace it than shorten the axle.
JD430C
Post by JD430C » Tue May 02, 2006 8:02 am
i think i have two. one in a bad tranny and one in a complete tranny. i will check today and let u know.
andrew
Ricky Sims
Post by Ricky Sims » Wed May 03, 2006 6:46 am
Sounds good, let me know what you have and how much you want for it. And also how quickly you can ship it. I can use a debit if you are set-up for that or I can send a cashiers check.
silerra
Post by silerra » Tue May 09, 2006 7:24 pm
I m working a a 1010 myself and this is just a thought but was the spring in the tube at the pinion end ?
silerra
Post by Lavoy » Tue May 09, 2006 7:25 pm
Ricky,
I was at the farm today, and discovered I do have a tranny there that still has the ring and pinion in it. It is an early serial number crawler.
Ricky Sims
Post by Ricky Sims » Wed May 10, 2006 6:31 am
The spring was in the right place. I have located a ring gear carrier here close to home, I am in the process of getting it. Thanks for the interest.
Users browsing this forum: Google Adsense [Bot] and 217 guests
