JD350C Reverser leaking
snowbear
Post by snowbear » Mon Mar 07, 2011 10:16 pm
I rebuilt my water pump only to have the reverser start leaking after I got it back together. I pulled the motor today, took about 4 hrs. This end of the machine sure is easy to work on.
So now I am looking at the reverser input, the seal looks pretty simple. I wonder if there is a way to find out if the gasket needs to be replaced as well. That could be much more involved and I really don't want to get into it. I'm thinking of putting some air pressure into the case thru the filler/dip stick and look for leaks.
Can someone help me with the torque specs for the pump cover holding the seal? I suppose I'd need the torque for the reverser front cover if I decide to take it off and the 4 engine bolts. I doubt I'll be able to get a good torque reading on the engine bolts but they'd be nice to know.
Any other tips would be greatly appreciated.
Thanx!
Donald erwin
Post by Donald erwin » Thu Mar 10, 2011 12:59 pm
THE TORQUE ON THE PUMP BOLTS ARE AT 35 POUNDS AND THE PLATE BOLTS
ARE AT 55 POUNDS THIS COME OUT OF THE JD BOOK I GOT FOR 350C'S
GOOD LUCK :D
snowbear
Post by snowbear » Thu Mar 10, 2011 3:46 pm
Thanx Donald.
Waiting on pump seal ring. Suppose to arrive today.
Users browsing this forum: Google [Bot] and 248 guests
