MC Starter Button
preppypyro
MC Starter Button
Post by preppypyro » Wed Jan 05, 2011 6:24 pm
Hey guys, I am currently working on a 1949 MC that I got from my uncle when he passed away.
The starter button hasn't worked for a few years, and Im just trying to determine which wires connect where, to get it going again. (I plan on building a new wiring harness for it one of these days, but its not any rush!)
One wire I assume goes to the solenoid (this solenoid has three prongs on it, one to the starter one to the battery, and one little one up top)
Does the other wire just come from the switch so that when ya turn the switch on, it sends power to the button, then by pressing the button that would engage the solenoid?
Someone have a picture of theirs?
Post by Lavoy » Thu Jan 06, 2011 2:49 pm
MC does not have a solenoid, someone has modified it, so there will not be a pic of what you have.
Post by JD440ICD2006 » Thu Jan 06, 2011 3:49 pm
As Lavoy said, these did not have a solenoid from the factory. The original wiring has a hot from the batt to the starter. It is a mechnical pull rod that makes contact to turn the starter.
If you want to keep it original, try to locate a 6 V starter with the mechnical switch on the side. The switches are readily avaiable. If you cannot locate an original pull rod, you can fab one out of round stock.
preppypyro
Post by preppypyro » Thu Jan 06, 2011 4:33 pm
Ah thanks for the info guys!
Im not concerned about keeping it 100 percent original, Im going to be "restoring" it like how my uncle, and grandfather had it when they were alive, and they must have modified it to be a push button start system, thanks very much!
markvdh
MC starter button
Post by markvdh » Thu Jan 13, 2011 8:44 am
Preppypyro,
You can wire this button whichever way you want to. If you want to be able to crank the engine without starting it (handy at times) then take the wire to the positive battery cable (either at the battery or at the starter). If you want it to only crank when you have the key on, then take the wire to the switch like you mentioned.
I just was thinking... has it been converted it to negative ground, or is it still positive ground? In fact, did they convert it to 12 volts?
Call me if you have any questions. I'll try to help.
Mark Van Der Hart
402-699-0621
MC (x2)
420C
440ICD
450
1010C
Mooney M20C
Cessna C150E
Murphy Renegade
Keep 'em crawling (or flying)!
Users browsing this forum: No registered users and 157 guests
