Looking for info on the tachometer on a 2010 crawler diesel, I have not been able to find on through deere dealer. Will any other deere Tach work in this crawler?
2010 crawler tach
You did not mention any part numbers. I have a 2010 diesel with a parts manual. I bought the tach cable at the local JD dealer without any problems. Here are the part numbers in question.
Tack - AT 17449T (it does not specify gas or diesel, must be the same)
Cable - AT 15470T for serial numbers to 42000
AT 17504T for serial numbers after 42000
You can try the JDParts website or contact your local JD Dealer for any cross-reference with wheeled tractors too. Then you can try a tractor junkyard if you knew what models to look for.
If you need a good tractor junkyard, there are several in Ohio I can recommend with phone numbers. Try ebay too.
JD 2010 Crawler with Loader
2010 tach
I have a 2010 crawler and a 2010 tractor. If you just want to know the RPM's, any 2010 tach will fit. The tach on my 410 backhoe is a different diameter (smaller). I suppose it could be made to fit with an adapter plate.
B.
B.
'63 2010 Dozer, '44 Model B Tractor,'65 2010 Tractor, '55 40c crawler, '77 2240 Orchard Tractor.
- Contact:
Re: 2010 crawler tach
You may want to check out these posts:jhv1050 wrote:Looking for info on the tachometer on a 2010 crawler diesel, I have not been able to find on through deere dealer. Will any other deere Tach work in this crawler?
http://www.jdcrawlers.com/messageboard/ ... tachometer
Users browsing this forum: No registered users and 163 guests
