One more track question....
The link measurement is easy to get wear percent. How about side play?
When a track is rolled out in a straight line, how much will it move to the side? I'm still trying to figure out a way to tell if the pins have been turned and I was wondering if this would be an indicator???
Any other way to tell?? Both 420 tracks I have do not indicate that the pins have been turned (loose pins, boss wear is minimal). One measures 100% wear the other 75%.
Lavoy wrote:Not even on the side that has run against the sprocket?
I measured a new bushing and the old tracks. Not a good accurate measure as they are all coiled, but I did the best I could with a caliper.
One measuring 25% remaining only shows approx .012-.015 wear. Wear only appears to be on one side
The newer 4 bolt, also meauring 25-30% remaining showed .018--.022 wear. Wear appears to be on both sides, some pins welded in.
The oldest one 100% worn out was also .018-.022 wear. Wear appears to be on one side.
No welds on the first and third tracks. My best guess is that only the newer track has been worked on looking at the pins and boss wear.
Users browsing this forum: No registered users and 211 guests
