450B reverser
mxzGary
450B reverser
Post by mxzGary » Sat Dec 04, 2010 9:47 pm
when I shift the reverser into r it slows the engine down even if I shift the trans into neutral. Seems to work fine in h or l
tjdub
Re: 450B reverser
Post by tjdub » Mon Dec 06, 2010 10:54 am
mxzGary wrote:when I shift the reverser into r it slows the engine down even if I shift the trans into neutral. Seems to work fine in h or l
Not that it's a big help to you, but the 450B didn't have a reverser. This is the H-L-R PowerShift transmission. I don't know what could be the cause, but it doesn't sound good. Have you tried changing out the fluid, filter, and cleaning the screen?
http://www.jdcrawlers.com/messageboard/ ... php?t=5222
Post by digitup2 » Thu Dec 09, 2010 11:41 am
get to your clutch packs the problem is in there.I don't remember what reverse is packed with but some one on here can tell you what clutch pack is paired up with reverse usually low pull the pack and check all bearings affiliated with reverse.Digitup.
Users browsing this forum: jimmydiesel and 364 guests
