Gearmatic 8 A project
Digger SR
Post by Digger SR » Sat Nov 20, 2010 2:59 pm
After alittle cleaning up. Yep, she's been used and abused
440 IC #448161 W/Henry loader, 3020 D, #8 mower
Digger SR
Post by Digger SR » Sat Nov 20, 2010 3:02 pm
In the process of removing the cap screw and bearing screw cap
Digger SR
Post by Digger SR » Sat Nov 20, 2010 3:04 pm
[/img]Image
Sucess..with the bearing screw cap
Digger SR
Post by Digger SR » Sat Nov 20, 2010 3:19 pm
Side cover came off pretty good considering how long its been sitting outsied in the elements. Patients and penatrating oil with some selective tapping with a hammer[/img]
Digger SR
Post by Digger SR » Sat Nov 20, 2010 3:23 pm
Now the other side. All the cover bolts were snapped off except 1. The 2 you see are the jacking holes after they were cleaned out with a 3/8ths tap. [/img]
CELSESSER
Post by CELSESSER » Sat Nov 20, 2010 9:06 pm
Digger sr,
Glad to see someone else uses a "Mobile Work Bench".
Chuck
Digger SR
Post by Digger SR » Sun Nov 21, 2010 9:04 am
yeah, I don't have access to a cherry picker..."YET" think there one in the future...(Christmas) from me, But is at the moment on a pallet in my garage now thanks to a couple of friends.
Digger SR
Post by Digger SR » Sun Nov 21, 2010 4:42 pm
Attempting to remove the Brake side Cover after soaking in pentatrating spray for a day and some light taping in selective areas with a hammer[/img]
Digger SR
Post by Digger SR » Sun Nov 21, 2010 4:44 pm
uck...now what?[/img]
Digger SR
Post by Digger SR » Sun Nov 21, 2010 4:45 pm
Back to the adapter plate... got the PTO shaft and bearing and oil seal[/img]
Digger SR
Post by Digger SR » Sun Nov 28, 2010 10:17 am
Any ideas on how that tube rod come apart off the break band? manual was very vague on it shall we say? 2nd to the last picture for those following along on the right had side
Jeff
Post by Lavoy » Sun Nov 28, 2010 11:53 am
The part above the tab on the band is like a push rod with the bottom end cut off. The bottom part goes up inside of it. They are probably rusted together, heat and vibration work the best.
Post by Paul Buhler » Mon Nov 29, 2010 10:30 pm
Hi: It looks like you're making progress. Congrats on getting the side covers off intact. To get the brake band off, remove the actuator located on top of the winch - it connects to the remote control lever that mounts on the fender, and you'll have access to the top of the rod that Lavoy mentioned. I soaked the actuator in brake fluid to get it working on mine.
Remove the three brake band retainers (Round plates with two screws each) looks like this may be a challenge - on mine I had to grind one broken screw off and drill and re-tap; not much meat to work with. There is a drift dowel that holds the brake band while it expands and contracts that is exposed near the winch drum and drives out from the cable side towards the cover side - you can see it in your ugh picture. Once you get these parts loosened or apart, the brake band should move more freely around the drum. There are paired alignment screws held with wires that center the bands over the clutch drum that you can't see yet. Good luck getting things cleaned up and free. Paul
Digger SR
Post by Digger SR » Tue Nov 30, 2010 9:09 pm
I kept working on them Lavoy and they finally came loose. Thanks
I got the actuator off today and... that pin gave in on me today. Thanks Paul. Didn't know it had to come out from the spool side. Anybody hear of this Gibbs penatrating oil before?...... so far so good. Them brake retainer discs are another story. All of them would not budge. So i just ground them off with the right angle grinder and will have to try and retap them later after i get the spider out, and then i can work on the those alignment screws alittle easier
Thanks for all your help.....keep it comming
Jeff
Digger SR
Post by Digger SR » Fri Dec 03, 2010 5:45 pm
Are those 2 holes in the bottom of the spider tapped and used to push against the drum to remove the spider from the center hub?
Users browsing this forum: No registered users and 180 guests
