Like Jack said, it's all mechanical inside, there's no hydraulics operating the clutch plate. That whine you hear is the right side steering clutch slipping under load. It will do the same thing if you're not pulling any lever and are trying to push on something. Either the clutch is partially engaged due to the clutch linkage being adjusted too tight, or the clutch is broken, worn-out, or oil-soaked.JD-thomas wrote:when I pull the lever the track stops driving, but the right one doesnt keep going to turn the machine. It sounds like a whine I stood up on it while driving, with inspection covers off looking down at clutch packs. The right side does fine, but the left when you pull the lever, it's like the brake band doesnt lock tight enough, but if you tighten it up it makes it jerk worse... It acts like there might be a pressure lose in spool valve that operates the clutch pack....
