how do I i post a picture
gerald
Post by gerald » Thu Nov 11, 2010 7:56 am
I have look evey where trying to figure how to post pictures. Gerald
Pammark
Post by Pammark » Fri Nov 12, 2010 9:11 am
Start by setting the size of your pictures to about 600 pixels wide. That will make a nice size picture and not too large.
Go to www.photobucket.com and setup an account using your e-mail address. It is free. Once you have an account, you can download your pictures to it.
You will see your small pictures shown with the top header [edit] [share] [delete]. Select the [share] and click [share now]. The top tab reads "Get Link Code" and click that. You will see a list of codes for the picture. 4th one down says "IMG for bullentin boards and forums" and highlight the code in the box "Full Size". Right click mouse and [copy]
Go to the JDCrawler post box and paste the code in.
You will see a long code similar to this;
http://i836.photobucket.com/albums/zz28 ... RIMER9.jpg[/IMG]
with a Image command says you are done with the image import. The pammark in the middle is my account. Your code will list your username. The PRIMER.jpg is the name of the picture to post.
If you have more than one picture, you can copy the code and paste again and again in the JDCrawler post box. Just edit the image filename for each one.
Let me show you how this works. I'll insert the code back in like it should with the Image
BINGO
JD 2010 Crawler with Loader
Post by Tigerhaze » Fri Nov 12, 2010 9:23 am
Mark gave a pretty good step by step explanation- there is also a post from me in the "Messageboard Q&A and Announcements" forum that describes and shows this process with pics as well.
gerald
nov 2010 befor the pm she is loading up
Post by gerald » Fri Nov 12, 2010 7:57 pm
gerald
testing the crawer out
Post by gerald » Fri Nov 12, 2010 8:01 pm
Image Im working on the hoe. I hobe it's a brutte the hyd are amazing 40 year old machine.
gerald
Post by gerald » Tue Feb 15, 2011 8:52 am
gerald
final removal 1970 350 crawer
Post by gerald » Tue Feb 15, 2011 10:13 pm
It was easy, the only thing i should have done was remove the final pan first. I had to use a comealong chaining it to the back the machine an let the jack off to get the pan off for cleaning an inspection. The pinion has a broke tooth. I got 1 0n order. It took longer to clean then to take apart. Image
gerald
Post by gerald » Tue Feb 15, 2011 10:33 pm
Image Im determined do photo Smart
gerald
Post by gerald » Tue Feb 15, 2011 10:47 pm
gerald
Post by gerald » Tue Feb 15, 2011 10:50 pm
gerald
Post by gerald » Wed Feb 16, 2011 11:22 pm
A little bit of trash there I'm thinking that it the proublem.
Someone said its easyer to fix it then trying to clean it an make it work . We have to learn the hard way. Image
Post by Lavoy » Thu Feb 17, 2011 10:16 am
Make sure you pull the drive shaft out, it should not have stayed in the rear end like that.
If you don't have access to a steam cleaner, Easy Off oven cleaner really strips the inside of a clutch housing well.
Users browsing this forum: No registered users and 196 guests
