Head bolts stuck on 440ICD
- BKahler
- Contact:
Help!
We're trying to break the head bolts loose on my 440ICD. So far using a 3/4" and then a 1" impact hasn't worked. In fact its snapped the sockets that have been tried so far. Unfortunately the engine is not on the crawler anymore so we're having a tough time finding a way to lock the motor down to use a long cheater bar with a wrench.
Any of you out there have a "been there done that" sort of answer?!
Thanks,
Brad
Thanks,
Brad
- BKahler
- Contact:
The impact wrench has already been tried. Tried both a 3/4" and then a 1" impact. All we did was break the sockets.Lavoy wrote:Use an impact wrench, the vibration will do a lot to loosen the bolts. If you are applying that much torque already, you can't hurt anything, and I would be inclined to put in new head bolts.
Once they are removed I'll definitely replace the studs!
Brad
- BKahler
- Contact:
Mike said he broke an impact socket plus some regular ones. That kinda surprised me but stranger things have happened. Right now we're trying to figure out a way to strap the engine to something so it can't turn and then use a long cheater bar. We'll see......JD40c wrote:Using impact sockets? Or regular hand tool sockets? Impact sockets are MUCH stronger.
Thanks,
Brad
Head bolts stuck on a 440ICD crawler
If the bolts are just tight and not rusted and if you are going to replace them anyway. I would torch the heads off of the bolts lift the cylinder head off and You should be able to take the bolts out by hand because they no longer have any tension on them.
- lastchancegarage
Brad,
Thay almost sound like stretch bolts. If you can cargo strap a stiff bar/pipe/angle iron along side the block and lay the block/bar assy on its side with the bar on the floor, you can then slide an extension over a 3/4" or 1" breaker bar and push down towards the floor. You might need someone to stabalize the block while you put one foot on the strapped bar while you loosen with the other one. Once you break the stretch torque they should loosen up quickly. If they are solidly rusted in, you'll probably snap the heads off applying pressure like this. That might not be a bad thing. One other note, use six point sockets only. Hope this helps.
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
- BKahler
- Contact:
Thanks for all the replies. We're going to try laying the engine down with a long pipe strapped to it to keep it from moving and then a long cheater bar with a breaker bar/socket.
Can't use a 6-point socket on a 12-point bolt head!
If this next attempt doesn't work then we'll likely torch the heads off and proceed from there.
I'll let you know how it turns out.
Brad
Brad
- lastchancegarage
Sorry about that Brad.
I've not had to tear into this engine yet so I assumed 1959...6 point head bolts.
Hey, 220, 221 whatever it takes. Hope that does the trick for you. It's definitely more of a challenge out of the frame. Good luck.
- BKahler
- Contact:
Used the suggested method of laying the engine on it side and strapping it to a trailer. Then used a good impact 12 point socket with a really long cheater/breaker bar. Even then the first day only two came out. More effort the second day finally broke them loose.shinnery wrote:Inquiring minds need to know, did you ever get it apart and how?
Needless to say those bolts are going to be replace!
Brad
- BKahler
- Contact:
Lavoy, I as rather surprised myself. But considering the age and the unknown people that have worked on it before nothing surprises me.Lavoy wrote:Brad,
This whole thing is really odd, there really should have been no way for them to get that stuck. I would definitely chuck the bolts, but I am wondering if you should run a good bottoming tap in all of the head bolt holes in the block.
I always clean out tapped holes as a rule when rebuilding an engine. Makes a huge difference in torque values.
Brad
PS, the check is finally in the mail. I'm the worlds worst procrastinator!
- lastchancegarage
Brad,
Glad to hear things worked out. Keep us posted on the progress. If you get a chance, maybe you could post a few pics. It'll be nice when I'm done with the landscaping to tear mine down. I'm hoping the pressure pot I'm building will speed up the blasting part of the project. Good luck on your resto.
Users browsing this forum: No registered users and 232 guests
