350 d hydraulic pressure
ignatiusreily
Post by ignatiusreily » Fri Nov 05, 2010 8:47 am
the hydraulic filter O ring blew out while operating yesterday, the filter may not have been on tight enough,...didnt need a filter wrench to remove.
any ideas?
Post by digitup2 » Fri Nov 05, 2010 8:58 am
If they aren't tight that is the first thing to go .The filter should be lubed with some oil all the way around and hand tight ,You can feel the filter seal set in as you tighten down.Digitup.
Users browsing this forum: No registered users and 299 guests
