JD 350B Steering Clutch Replacement Estimate
GlennP
Post by GlennP » Sun Oct 24, 2010 9:02 pm
What is a reasonable time estimate to replace a steering clutch on a 350B? One side only. Thanks!
1970 350B Crawler Loader
Post by digitup2 » Mon Oct 25, 2010 6:21 am
Around five cases of beer would be a reasonable time frame.It all depends on what you find when gettin into it and if you have all the tools or have to waite on parts .I have had them come apart nice and others would be considered a nightmare.Digitup2.
MattE
Post by MattE » Mon Oct 25, 2010 10:09 am
digitup hit in on the head 6-60 hours depending on ease of disassembly and how much beer is consumed in process. If you've got a reasonably well equipped shop, a manual and all the parts (provided nothing has self destructed on the inside) you should be able to do it on a good Saturday.
GlennP
Post by GlennP » Tue Oct 26, 2010 10:14 am
Thanks guys. I have a heavy equipment shop lined up to do the work and we are trying to determine what is a reasonable time estimate. The shop is willing to charge based on actual time estimates experienced by others working on the 350. It sounds like we are talking a full day of shop time. They have no experience working on this particular unit. Appreciate your help on this! Cheers!
DBCSteve
Post by DBCSteve » Tue Oct 26, 2010 6:27 pm
GlennP wrote:Thanks guys. I have a heavy equipment shop lined up to do the work and we are trying to determine what is a reasonable time estimate. The shop is willing to charge based on actual time estimates experienced by others working on the 350. It sounds like we are talking a full day of shop time. They have no experience working on this particular unit. Appreciate your help on this! Cheers!
Just getting the assembly out takes a lot of time. Need to remove the seat, entire fuel tank/hydraulic reservoir assembly (meaning you need to disconnect all fuel and hydraulic lines), etc. If all that is done in the shop and you simply drive it in, that would be great. I used a backhoe to remove that stuff, after breaking the tracks on the side that has to be removed. Then took the unit in to Pape Machinery and they did the rebuild for about $450 US including parts. Did not replace throwout bearing, just the clutch pack and pressure plate.
JD 450C, Serial No. 316559T
Kubota L3400 top-n-tilt
gerald
350 steering clutchs
Post by gerald » Sun Oct 31, 2010 9:12 am
My 350 right side was bad I released the adjustment bolt all the way out dumped gallon of minural spirits in the hole and found the brake hung up i freed it up with a cat bar sprayed 5 cans of brake cleaner left it set a month ran the bolt all the way in backed it 2 1/2 out started right up an it spun on a dime wow. I didnt work it long because it need PM . I have the cluth kit ready when I need it and not looking forward to the job.
Users browsing this forum: No registered users and 240 guests
